Log to LOG4OM
ON3CQ
Log to LOG4OM
Post by ON3CQ »
I use JTDX rc147 and JTAlert 2.15.8 wen i have logged the station, the call from the logged station will remain in the Callsign field from log4om. The call remove in JTDX. I must remove manuel the call in log4om with press the red X. This a bug in log4om or setting not ok here ?
Re: Log to LOG4OM
Think the settings are o.k. and when you hit another station in JTDX the Call in the main UI will be changed automaticly.
Not a bug not anything else. Think you have setted up JT_Message to force via UDP callsign goes to L4O main UI.
For me personally i don´t force JT-Message to play the call into V2. I log still only worked contacts from JTDX via
JTalert to V2.
ON3CQ
Re: Log to LOG4OM
Post by ON3CQ »
Juergen this are the settings here i must fix something ?
Aantekening 2020-02-02 163857.jpg (41.36 KiB) Viewed 3433 times
Re: Log to LOG4OM
As a first look i will say stop JT_Message
ON3CQ
Re: Log to LOG4OM
Post by ON3CQ »
Ok Juergen the problem fix now tnx for the info.
73 Pat
ON3CQ
Re: Log to LOG4OM
Post by ON3CQ »
Maybe something else that you can adjust in LOG4OM. Always used N3FJP and there was the moment that call came in log, callsign field was emptied.
KE4BCN
Re: Log to LOG4OM
Post by KE4BCN »
I was having problems also finally got it all working. Thanks for support..
