why is error in aif exported from L4OM?
not possible to import to others logs.
"Error : Frequency does not appear to be in the 20M Band: <ANT_AZ:1>0 <BAND:3>20m <CALL:4>9Y4D <CONT:2>SA <COUNTRY:17>Trinidad & Tobago <CQZ:1>9 <DXCC:2>90 <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>R <FREQ:12>14.204000 <GRIDSQUARE:6>IM66vl <ITUZ:2>11 <LOTW_QSLRDATE:8>20180220 <LOTW_QSL_RCVD:1>Y <LOTW_QSL_SENT:1>Y <MODE:3>SSB <NAME:11>CHRISTOPHER <OPERATOR:6>SP7EWL <STATION_CALLSIGN:6>SP7EWL <PROGRAMID:6>Log4OM <PROGRAMVERSION:7>2.3.0.0 <QSLMSG:19>TNX FOR QSO TU 73!. <QSLSDATE:8>20180106 <QSL_RCVD:1>N <QSL_RCVD_VIA:1>E <QSL_SENT:1>Y <QSL_SENT_VIA:1>E <QSO_COMPLETE:1>Y <QSO_DATE:8>20130823 <QSO_DATE_OFF:8>20130823 <QTH:12>SAN FERNANDO <RST_RCVD:2>59 <RST_SENT:2>59 <SWL:1>N <TIME_OFF:6>204900 <TIME_ON:6>204900 <PFX:3>9Y4 <QSO_RANDOM:1>Y <SFI:1>0 <IOTA:6>SA-011 <IOTA_ISLAND_ID:6>SA-011 <EOR>"
"Error : Frequency does not appear to be in the 80M Band: <ADDRESS:35>Klonowa 26 11-034 Pluski Poland <A_INDEX:1>9 <ANT_AZ:1>0 <BAND:3>80m <BAND_RX:3>80m <CALL:8>SQ4IOH/4"
This error i in all exported from L4OM records!!!
Export adif from Log4OM
Re: Export adif from Log4OM
Sounds like the freq is outside your bandplan but as you don't display the freq we can't comment
No dear Terry it is not amy band mape mistake it is bad format of exported by L4OM file adif.
Adif Master http://www.dxshell.com/adif-master.html
can not open adif file exported by L4OM, and after import L4OM adif looks like quite diffrent format against a normal from other programs.
And a question HOW to get a normal adif from L4OM?
73 Zbig SP7EWL
73 Zbig SP7EWL
- Zrzut ekranu 2020-02-23 17.51.53.png (51.24 KiB) Viewed 6250 times
- Zrzut ekranu 2020-02-23 17.52.24.png (60.27 KiB) Viewed 6250 times
Hi Zbig,sounds like a problem in your export,maybe a Windows admin privileges issue ? You tried to export to another folder or unit ?
I can export adif files without problems, Adifmaster opens them correctly, and, in fact I export them to qrz.com.
I attach a newly exported adif
73 Jorge
LU1DA
73 Jorge
LU1DA
I found at exported from L4OM adif file a difrent lenght of data in field <Field:L>data
where L is a lenght of data and at L4OM this lenght is 12 however is use only lenght 9
<FREQ:12>14.075417
wsjt log and Logger32 adi this field is designed for lenght of 9
wsjtx log - <freq:9>14.075417
and Logger32 adi field is the same as wsjtx log - <FREQ:9>14.075417
So, I think this is a reason of error during import from L4OM to Logger32
____________________________________________________________________________________________
Logger32 (Version 3.50) ADIF file import exception(s).
Source file - d:\logger32\lotw raports\log4om_adif_20200228210759.adi
Created 28.02.2020, 23:09
Operator - SP7EWL
<EOH>
Error : Frequency does not appear to be in the 20M Band: <ADDRESS:39>10 Bp 3160 Abidjan 10 Ivory Coast <A_INDEX:1>4 <ANT_AZ:1>0 <BAND:3>20m <CALL:6>TU5PCT <COMMENT:8>FTDx5000 <CONT:2>AF <COUNTRY:13>Cote d'Ivoire <CQZ:2>35 <DISTANCE:7>5475.58 <DXCC:3>428 <EMAIL:14>[email protected] <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>R <FREQ:12>14.075551 <GRIDSQUARE:6>IJ76ht <ITUZ:2>46 <LOTW_QSLSDATE:8>20200228 <LOTW_QSL_RCVD:1>N ......................................................
Vy 73
Zbig SP7EWL
<FREQ:12>14.075417
Operator - SP7EWL
<EOH>
Vy 73
Zbig SP7EWL
Success, I changed the entire adi file from L4OM data field length from 12 to 9 and I imported this file to Logger32 without any errors
As in the attached screenshot
Vy 73 Zbig SP7EWL
Vy 73 Zbig SP7EWL
Dear Daniel
Should I understand that yours "Thanks for reporting. Fixed" means you will correct this in the structure of the adif file exported from Log4OM?
Will you change the field length from <FREQ:12> to <FREQ:9>?
Regards
Zbig - SP7EWL
Regards
Zbig - SP7EWL
Hi Zbig,
that means it is fixed in Alpha yet. In the next upcoming release it will work for all users
too. Think in a few days it´s availible for all.
