User Guide Error - Connecting direct to JTDX
K5EY
Post by K5EY »
I think there is an error on page 146 (Connecting direct to JTDX) of the current Log4OM User Guide:
  • Both primary and secondary UDP ports are displayed as 2333. One of them should be 2237.
This is what works for me:
JTDX Reporting.png (46.36 KiB) Viewed 5282 times
Charlie -- K5EY
Denton, Texas USA
Log4OM 2 (ver. 2.14.1.0)
Using JTDX (ver. 2.2.156) and JTAlert (ver. 2.50.1)
Intel Core i7-8700 @3.20 GHz (12GB RAM)
Windows 21H1
Re: User Guide Error - Connecting direct to JTDX
Thanks for spotting that, I have corrected it and will upload later.
At least the text was correct!
Updated and ready for download
sq9jxb
Post by sq9jxb »
When set as below, everything works without any problems.
Primary Port UDP - 2233
Secondary Port UDP - 2237
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
sq9jxb wrote: 24 Feb 2020, 13:18 Hello
Jan,
Over the past many months of testing I've tried those ports as well and (as you have noted) they work well.
Part of the joys of ham radio are the options and variables that we can each come up with to make things work best for our stations.
We try to settle on a group of settings that we have tested and find that work for most situations. Ergo ... what we have in the User Guide and (goes without saying) that it can be subject to change based upon APP changes from the other providers as well. Can be a moving target many times.
Thanks for you sharing and input.
sq9jxb
Post by sq9jxb »
Hello Nolan KI5IO
This is your hobby ......... looking for a hole in the whole. :). And especially in software.
In most cases, it succeeds, and if not, colleagues help. The new version of the program, new options, everything does not always work as we would like, but after a while and the help of others works.
I am waiting for the possibility of logging in via the API to QRZCQ.com as it is solved with QRZ.com, and the introduction of the RESTORE option in restoring the log and settings, e.g. after changing the computer what awaits me in the near future.
So far he is happy with the program.
Great respect for developers and testers.
Regards
Edit: I use translator
73!
Jan SQ9JXB
sq9jxb wrote: 24 Feb 2020, 16:08
You will not get an API upload to QRZ because you are not a Paid QRZ subscriber, your listed as a Ham Member so not only will API upload not work but you will not get a full QRZ lookup
sq9jxb
Post by sq9jxb »
G4POP wrote: 24 Feb 2020, 16:17
Hello Terry
No no no :)
I mean upload using the API on QRZCQ.com where I have a Premium account.
  I gave QRZ.com as an example.
73!
Jan SQ9JXB
sq9jxb wrote: 24 Feb 2020, 16:37
Hello Terry
No no no :)
Have QRZCQ got an API service?
have checked the qrzcq website i don´t find anything about automatted uploads via API.
So think they don´t have it yet. But i can ask the owners if needed. Both are german hams.
sq9jxb
Post by sq9jxb »
https://www.qrzcq.com/page/developers
JSON API for account data (auth, read-write) <- ALPHA, PLEASE USE AT YOU OWN RISK
• API Url: here (https://www.qrzcq.com/api/ or http://qrzcq.com/api/) (docs todo)
### UPLOAD your logbook to QRZCQ ***
Assume your call is AAA, your API-Key is BBB, your logbook in
ADIF, post a json encoded object to this URL:
https://ssl.qrzcq.com/api/logupload
Request:
stdClass Object
[auth] => stdClass Object
[call] => AAA
[key] => BBB
[data] => stdClass Object
[adif] => (json encoded adif)
A response could be:
stdClass Object
[status] => OK
[message] => DATA_QUEUED
[request] => stdClass Object
[method] => logupload
[opt1] =>
[opt2] =>
[opt3] =>
[postdata] => stdClass Object
[call] => AAA
[key] => ********
[cpu] => 0.003
You should post no more than 1x per minute.
73!
Jan SQ9JXB
