problem Voice record on air
lz2ao
Re: problem Voice record on air
Post by lz2ao »
No image
If you try to sent us a screenshot please use the "Attachments" tab below the text field in the editor.
With upload you can search the image at your poc and load it up. Place inline button is placing the
image in the text field.
Don´t use the picture button in editor, this is only for images from an external source and need a
link to the image.
lz2ao
Post by lz2ao »
CAT interface.jpg (19.13 KiB) Viewed 5327 times
audio devices.jpg (22.01 KiB) Viewed 5327 times
lz2ao
Post by lz2ao »
Hello,is there anyone with Yaesu FT dx3000,who uses voice transmition (Log4om v2) to help me with the settings?
73's LZ2AO
Your pictures are not readable for us after you posted them.
lz2ao
Post by lz2ao »
Hello again
lz2ao
Post by lz2ao »
lz2ao
Post by lz2ao »
f4gwm
Post by f4gwm »
i have a ftdx 3000 and i have try the voice keyer too but i have the same problem
if you put your trx on data usb you can see that the audio go on the air but if you are on usb or lsb nothig only the ppt is active but no audio.
It is the same here i have try with other software and it is working but not on log4om i think it is a software problem not a hardware.
just save your configuration on turn your trx on data usb and you can see all is ok
so it is not a problem of audio configuration
i have try with many software and it is working on usb not necessary to go on data mode the problem is only in log4om
F4GWM
CEDRIC
