Adding “Distance” value
2E0GJH
Post by 2E0GJH »
Using v2.3.0 how can I add the “distance” value when editing a QSO?
QRZ sourced information excludes the grid locator as do some longer FT8 CQ calls, but having looked up the locator manually and entered it into the QSO and updated/saved there is still no distance calculated. Is it possible to do so?
Re: Adding “Distance” value
A example please so that I can test
2E0GJH
Post by 2E0GJH »
Steps to reproduce.
Show the “Distance” column in the main QSO table.
Add a QSO with a valid grid locator.
That QSO has a value in the distance field.
Add another QSO with no grid locator.
Edit the QSO to add a grid locator.
That QSO does not have a value in the distance field.
Correct because editing a QSO does not update it if there is not a locator to work on when added or edited
2E0GJH
Post by 2E0GJH »
Yes but I've said I added the grid locator manually during editing Terry, surely then the distance can be added?
2E0GJH wrote: 25 Feb 2020, 14:35 Yes but I've said I added the grid locator manually during editing Terry, surely then the distance can be added?l4om.png
No it does not recalculate from edit screen even though youn added the locator
2E0GJH
Post by 2E0GJH »
I think I might be confused here - In your earlier post you said "Correct because editing a QSO does not update it if there is not a locator to work on when added or edited" (my emphasis) - but now you say it doesn't do anything with distance other than when the record is first created?
Can this please be submitted as a bug report or feature request then Terry?
Otherwise what function does the distance value have. Is there any other way to populate the distance value as I can't see it in the edit QSO screen?
IU4MTO
Post by IU4MTO »
I've the same problem, once I edit WWlocator of previous QSO (for example in the existing QSO the locator is only 4 character ... because I import adif from WSJT-X ....), the distance is not calculated.
Has anyone solved this issue ? Is it a bug or we are missing something ?
Fabrizio IU4MTO
WSJT-x and JTDX only provide the 4-digit grid/locator codes.
Correct me if I am wrong.
But I think Log4OM only calculates from center of country to center of country? It might use a grid but I think that grid is in the center of country.
Does Log4OM handle WSJT data differently?
