Countries NOT imported/updated when importing log from n1mm
Just uploaded my contest log and none of the entries have the country listed. How can this be fixed without having to edit hundreds of records one by one?
Re: Countries NOT imported/updated when importing log from n1mm
Ed,W2GTR wrote: 09 Mar 2020, 13:58 Just uploaded my contest log and none of the entries have the country listed. How can this be fixed without having to edit hundreds of records one by one?
Did you use the Apply country corrections on load option? The image below is from the current version of the User Guide on Page 16.
- V2-ADIF-Import.JPG (90.76 KiB) Viewed 6147 times
No, there is no checkbox for that. The only checkbox available is to drop the current database.
Using v2.4.0.0
Using v2.4.0.0
Please OM,
check again the procedure that Nolan has provided in his Screenshot and do it step by step.
You haven´t hit on "Load" you haven´t navigated to an ADIF to Import and you don´t have
klicked that ADIF. The Checkbox is only active if a ADIF for import is selected.
Ed,W2GTR wrote: 09 Mar 2020, 14:26 No, there is no checkbox for that. The only checkbox available is to drop the current database.
Using v2.4.0.0
Did you look at the N1MM Contest Logger Integration? It is noted on Page 158 of the most current User Guide.
Here is the same screen with the adif "loaded". I still do not see a checkbox to update countries.
Forget the check box it was changed to a drop down a short while ago and option 1 from the drop down does what you require
Yes, but I am not trying to have qso's updated live. I am importing an adif file after the contest is over.
KI5IO wrote: 09 Mar 2020, 15:37
Ed,
Yes, I see the dropdown box, but the countries were NOT added/updated when I imported the log.
So how do I get the countries updated for the hundreds of entries that are now in log4om with no country listed?
G4POP wrote: 09 Mar 2020, 15:43 Forget the check box it was changed to a drop down a short while ago and option 1 from the drop down does what you require
Qso manager
Select Qso's needing country updates
Click the 'Update button
It will take some time if there are a lot of Qso's so be patient
