For eQsl and LOTW I prefer a simple "No" in the log when not received yet rather than "Requested". I've changed the default confirmations accordingly and this works fine for SSB QSO's but for FT8/FT4 they always still say "Requested". I tried the bulk editor but you can't update these fields there. Am I missing a trick?
73 Phil M0TZZ
QSL Status for FT8 QSO's
Re: QSL Status for FT8 QSO's
Hi Terry
In Settings>User Configuration>Confirmations
Should do it?
73 Phil
Should do it?
73 Phil
Yes it should so if ft8 are still arriving requested I suspect wsjt or jtalert are setting that status and we won't override an existing status in an inbound QSO
OK thanks Terry will look into that
Stay safe 73
Stay safe 73
Took 5 seconds once I knew where to look - thanks again
