QSL Status for FT8 QSO's
M0TZZ
Post by M0TZZ »
For eQsl and LOTW I prefer a simple "No" in the log when not received yet rather than "Requested". I've changed the default confirmations accordingly and this works fine for SSB QSO's but for FT8/FT4 they always still say "Requested". I tried the bulk editor but you can't update these fields there. Am I missing a trick?
73 Phil M0TZZ
Re: QSL Status for FT8 QSO's
Where did you change the default confirmation settings?
M0TZZ
Post by M0TZZ »
Hi Terry
In Settings>User Configuration>Confirmations
Should do it?
73 Phil
Yes it should so if ft8 are still arriving requested I suspect wsjt or jtalert are setting that status and we won't override an existing status in an inbound QSO
M0TZZ
Post by M0TZZ »
OK thanks Terry will look into that
Stay safe 73
M0TZZ
Post by M0TZZ »
Took 5 seconds once I knew where to look - thanks again
