QSO sent to LOTW but not received...
IZ4JUK
Post by IZ4JUK »
I just noted that since I installed this new version of LOG4OM (Version 2, now 2.4.0.0.), I send corrctly my QSOs to LOTW, but even if I don't get any error in the download, I don't receive the confirmation.
In the column RECEIVED I only see the word "Requested" instead of "YES".
Below 2 screenshots, one where it is possible to see any reported error when I download from LOTW, another screenshot showing an example (a QSO with T6AA) confirmed on LOTW and "requested" on LOG4OM.
Where am I wrong?
Thanks in advance for your help.
Joe IZ4JUK
PA3FAT
Re: QSO sent to LOTW but not received...
Post by PA3FAT »
Have something similar.
Have 12 confirmations in Lotw, since whenever, adif gets downloaded. Only 1 QSO marked YES.
Where is the adif that is being downloaded so i can check the contents of LOTW download. For now i cannot see what is the actual content.
LOTW confirmed QSO since forever.png (64.37 KiB) Viewed 4024 times
tn_LOG4OM lotw status.jpg (8.71 KiB) Viewed 4024 times
Don't want to hijac the thread. So please support the first requester.
PA3FAT
Post by PA3FAT »
Got mine ok, i think. I did "Last Download" marked and the "received since" in my case 1-nov-2019. That gave me the 12 records.
Selecting in a date range eg 1-1-2007 to 18-4-2020 (european notation) only gave me the last confirmed.
So there is something wrong in what is requested from LOTW or not all the fields are passed through.
Where can i find what is going to LOTW? So i might be able to give some feedback.
PA3FAT
Post by PA3FAT »
@Joe IZ4JUK
You should set the received since date earlier.
Look at your confirmation date in the QSL field. It is on the same date as the QSO.
So make your since date that date or earlier.
If you miss more confirmations. Make the since date e.g. 1-1-1980.
Then you get all confirmations. As you see did almost same in my solution.
Ron/PA3FAT
IZ4JUK
Post by IZ4JUK »
Many thanks Ron, that was the problem!!
Very kind of you spending some of your time looking at this problem of mine!
Reading "from" in the first field and the second field with another date, I wrongly read it as "to" instead of "sice", as in default it sets this date to the current date...
I just have to remember each time to change this date.
Problem solved. Thanks again.
"73
Joe IZ4JUK
wb2bin
Post by wb2bin »
Yes, it is working now.
Thanks,
Greg
PA3FAT
Post by PA3FAT »
Greg,
Thanks for feedback that it is working :)
Ron
