Today when I saw my HRDLog map I wondered about the new markers, which are not set correct as they are in the center of the DXCC:
I went into the details of the HRDLog logbook and saw that the locator does not match the one stored in Log4OM.
Im my Log4OM I have FN46 stored (from WSJT-X):
Im my Log4OM I have QF23 stored (from WSJT-X):
I switched from Log4OM v1 to v2 2.4.0.0 only a week ago and immediately updated to 2.5.0.0.
I can say that it worked with v1 correctly.
Is it possible that no locator is sent via API and HRDlog just uses a default locator with the country?
Does it possibly also have something to do with the new duration between entry in the log and sending the data to HRDLog? I have the feeling that the new feauture may be related to the problem.
Can I somewhere check the raw api-data sent by Log4OM to external sources?
HRDLog does not show correct locators
https://www.dk9jc.de
Re: HRDLog does not show correct locators
In Help turn on trace mode and then either watch the realtime log or open the logfile
Thank you, Terry.G4POP wrote: 23 Apr 2020, 07:40 In Help turn on trace mode and then either watch the realtime log or open the logfile
For the log from wsjt-x to Log4OM v2.5.0.0 I get:
In the raw data (DB SELECT) I see "GridSquare":07:42:07.218 Debug: ##### UDP MESSAGE RECEIVED ##### :JTAlert<EOH> <CALL:5>OH3OJ<QSO_DATE:8>20200423<QSO_DATE_OFF:8>20200423<TIME_ON:6>074000<TIME_OFF:6>074100<FREQ:9>14.075922<FREQ_RX:9>14.075922<BAND:3>20m<BAND_RX:3>20m<MODE:3>FT8<DXCC:3>224<COUNTRY:7>Finland<CQZ:2>15<ITUZ:2>18<CONT:2>EU<RST_SENT:3>-03<RST_RCVD:3>-04<LOTW_QSL_SENT:1>R<LOTW_QSL_RCVD:1>R<EQSL_QSL_SENT:1>R<EQSL_QSL_RCVD:1>R<GRIDSQUARE:4>KP20<DISTANCE:4>1689<TX_PWR:3>10<LAT:11>N060 30.000<LON:11>E025 00.000<COMMENT:35><NAME:14>Jukka<QTH:9>Riihimaki<PFX:3>OH3<MY_GRIDSQUARE:6>JN39MF<MY_CQ_ZONE:2>14<MY_ITU_ZONE:2>28<STATION_CALLSIGN:5>DK9JC<QSO_COMPLETE:1>Y <EOR> on UDP port 2235 (JTALERT QSO/ADIF_MESSAGE) from 127.0.0.1:61048#####
[...][HRDLOG] Sending ON AIR message
07:43:46.764 Trace: [DbSqlite] : SELECT QsoId, Callsign, Band, Mode, QsoDate, Address, StationCallsign, DXCC, ArrlSect, QsoComplete, Age, AIndex, AntAz, AntEl, AntPath, Antenna, ArrlCheck, BandRX, CallsignUrl, Class, Cnty, Comment, Cont, ContactAssociations, ContactedOp, ContestId, Country, CQZone, Distance, EqCall, EMail, ForceInit, Freq, FreqRx, GridSquare, ITUZone, KIndex, Lat, Lon, MaxBursts, MSShower, MyAssociations, MyDxcc, MyLat, MyLon, MyCity, MyCnty, MyCountry, MyCQZone, MyGridSquare, MyITUZone, MyName, MyPostalCode, MyStreet, MyRig, MySig, MySigInfo, MyState, Name, Notes, NrBursts, NrPings, Pfx, Operator, OwnerCallsign, Precedence, PropMode, ProgramId, ProgramVersion, QslMsg, QslVia, QsoEndDate, QsoRandom, Qth, RxPwr, Sig, SigInfo, RSTRcvd, RSTSent, SatelliteQSO, SatMode, SatName, SFI, SRX, SRXString, State, STX, STXString, SWL, TxPwr, QsoConfirmations, ContactReferences, MyReferences FROM LOG WHERE QsoId = @qsoId
07:43:46.806 Info: [#=zP9Ak_P34NrL9JNWNZMeU$Dld8yiB] : [HRDLOG UPLOAD] Uploading QSO on HRDLOG: OH3OJ|23.04.2020 07:40:00|20m|FT8
In the uploaded data I do not see "GridSquare" or "Locator":
[HRDLOG UPLOAD] payload:http://robot.hrdlog.net/NewEntry.aspx payload: Callsign=DK9JC&Code=XXXApp=LOG4OM2&ADIFData=<BAND:3>20m <CALL:5>OH3OJ <COMMENT:35><DXCC:3>224 <FREQ:9>14.075922 <MODE:3>FT8 <STATION_CALLSIGN:5>DK9JC <QSO_DATE:8>20200423 <RST_RCVD:3>-04 <RST_SENT:3>-03 <TIME_ON:6>074000 <EOR>
07:43:46.924 Debug: [#=zxpoxaO_Q5llSf_fvXg==][MoveNext] : PostDataAsync: Posting data to http://robot.hrdlog.net/NewEntry.aspx. upload information:Callsign=DK9JC&Code=XXXApp=LOG4OM2&ADIFData=<BAND:3>20m <CALL:5>OH3OJ <COMMENT:35><DXCC:3>224 <FREQ:9>14.075922 <MODE:3>FT8 <STATION_CALLSIGN:5>DK9JC <QSO_DATE:8>20200423 <RST_RCVD:3>-04 <RST_SENT:3>-03 <TIME_ON:6>074000 <EOR>
[HRDLOG UPLOAD] ###### END ######
I just enabled tracing in v1.40.0.0 and checked which fields are sent to HRDlog there.
Unlike in v2.50. the field "<GRIDSQUARE:4>" is there in 1.40.
AdifManagement: Begin HRDLog row creation for Call: LA8OOA Date: 20200426 Time: 120700 Band: 15m Mode: FT8
Log4OMMainWindow: QSO Added via External Form for QSO : Call: LA8OOA Date: 20200426 Time: 120700 Band: 15m Mode: FT8
AdifManagement: End HRDLog row creation for Call: LA8OOA Date: 20200426 Time: 120700 Band: 15m Mode: FT8
TCPEventManager: QSO Added via AddQso from UDP for QSO : Call: LA8OOA Date: 20200426 Time: 120700 Band: 15m Mode: FT8
HRDLogManagement: upload informations:
Callsign=DK9JC&Code=[XXX]&App=Log4OM&ADIFData=<QSO_DATE:8>20200426 <TIME_ON:6>120700 <CALL:6>LA8OOA <MODE:3>FT8 <BAND:3>15m <FREQ:9>21.075996 <RST_SENT:3>+10 <RST_RCVD:3>+02 <QSL_SENT:1>R <QSL_RCVD:1>R <QSL_SENT_VIA:1>B <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>R <LOTW_QSL_RCVD:1>R <LOTW_QSL_SENT:1>R <DISTANCE:4>1039 <STATION_CALLSIGN:5>DK9JC <GRIDSQUARE:4>JO28 <DXCC:3>266 <EOR>
HRDLogManagement: upload result 1
Thank you for completing that test it saves us some time
I will report this to Lele
Added fields on next release. Alpha testing in progress.
Thanks a lot, i love that reports! really save me a lot of time to find and fix it (less than 5 minutes in that case)
Thank you, Terry.G4POP wrote: 26 Apr 2020, 12:38 Thank you for completing that test it saves us some time
Thank you, Daniele. I have a lot of experience in this field from my work. Daily business. Thank you for the quick fix. Let me know if you want me to do some tests. I will report another (small) issue soon.IW3HMH wrote: 26 Apr 2020, 15:49 Added fields on next release. Alpha testing in progress.
I can confirm that the bug is fixed in v2.6.1.0 and everything is now working correct. Tu for this great fix.
Thanks for letting us know!
Doug
W7DRM
Doug
W7DRM
