How do you get the second frequency display to come alive? Is this for SO2R or am I missing something? Using Flex 6300.
Frequency Display
Re: Frequency Display
Seems like a CAT issue. Check your CAT settings. If its installed correct both VFO's should show. I am using Omnirig.N4PYI wrote: 24 Apr 2020, 00:11 How do you get the second frequency display to come alive? Is this for SO2R or am I missing something? Using Flex 6300.
Mike-W2MJP
Mike-W2MJP
hi,
still no luck with latest log4om second vfo. Here is my setting window.
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
I am using Omnirig version 1 not 2. I believe there is a issue with Omnirig V2 and Log4om V2. They don't play nice. If your not already using Omnirig V1 try it. I also don't know anything about the Flex radios. I am using a IC 7610.
Mike-W2MJP
Mike-W2MJP
Not all radio command sets support CAT visualisation of both VFO'sN4PYI wrote: 24 Apr 2020, 00:11 How do you get the second frequency display to come alive? Is this for SO2R or am I missing something? Using Flex 6300.
I note that you have been a registered user for some time so you were probably using V1 of Log4OM, did dual VFO display for this radio work with V1?
It did not. And I suspected that it might be "radio related". The Flex radio requires that each com port be set to a slice or VFO.
Thanks!
Thanks!
Brad, N4PYI
Brad, N4PYI
With the Flex, you can add a second rig in OmniRig after setting up another serial port in SmartSDR CAT. You can toggle between those two but I have not been able to get the Flex to work with OmniRig VFO A/B config.
You can also use HamLib instead of omnirig and using Slicemaster the Log4om frequency will change based on active slice.
