UDP Proxy Configuration
KD9NHZ
Post by KD9NHZ »
Backgound:
I am trying to get Log4OM2 to repeat messages received from WSJT-X to anther UDP port. The objetive was to have another application to receive data traffic from WSJT-X on the same computer.
WSJT <---> [port 2237] <---> Log4OM2 ---> [port 42237] ---> AnotherApp
The AnotherApp is really only a pyhon script, receive only. No problems with receving messages directly from WSJT.
I configured UDP Proxy connection:
[ ] [UPD Proxy][JT_MESSAGE][From 127.0.0.1:2237][To 127.0.0.1:42237] JT_PROXY_4
Problem:
Not receiving any packets on port 42237. In the config file the "Enable" is set to false. Tried to edit config manually - setting it to true does not help, Log4OM2 changes it back to false.
Not sure what I'm doing wrong here...
Log4OM2 version 2.6.1.0 on Windows 10 Pro version 1909 x64
Here is my config:
Code: Select all
          "Enabled": false,
          "Name": "JT_PROXY_4",
          "NetworkConnectionType": 5,
          "NetworkInboundMessageType": 3,
          "NetworkOutboundMessageType": 0,
          "DefaultAnswer": "",
          "SourceAddress": "127.0.0.1",
          "SourcePort": 2237,
          "TargetAddress": "127.0.0.1",
          "TargetPort": 42237,
          "Broadcast": false
And, Thank you for your work!
NN7D
Re: UDP Proxy Configuration
Post by NN7D »
Dear ?,
Could you please post a screenshot of your Proxy settings in Log4OM. Will try to replicate your issue.
Doug
W7DRM
Try a shorter target port number
KD9NHZ
Post by KD9NHZ »
Tested with shorter port number, did not help.
Setting screenshot attached:
73, Piotr KD9NHZ
