Clublog: QSO shows "SATELLITE, INTERNET OR REPEATER" - RX band 10m
DK9JC
Post by DK9JC »
Yesterday I was outside and did 2m SSB/FM from a SOTA-Summit. I logged on paper and entered it all into Log4OM v2.6.1.0 afterwards.
It looks like this on clublog with "SATELLITE, INTERNET OR REPEATER" shown as mode:
Clublog 2020-06-03_11h07_09.png (18.66 KiB) Viewed 6083 times
I did some investigation in the log. No submode is ticked. The only thing I see is that there is no RX QRG entered and it is shown as "0".
Log 2020-06-03_11h07_59.png (16.15 KiB) Viewed 6083 times
Here is an ADIF-Export of one of the QSO. You can see that Band RX is 10m. I guess this is the problem:
<ADDRESS:16>Frouard
France <A_INDEX:1>6 <ANT_AZ:3>219 <ANT_EL:1>0 <BAND:2>2m <BAND_RX:3>10m <CALL:7>F0CVO/P <CONT:2>EU <COUNTRY:6>France <CQZ:2>14 <DISTANCE:6>106.74 <DXCC:3>227 <EQSL_QSLSDATE:8>20200602 <EQSL_QSL_RCVD:1>R <EQSL_QSL_SENT:1>Y <FREQ:10>144.275000 <GRIDSQUARE:6>JN38br <ITUZ:2>27 <LOTW_QSLSDATE:8>20200602 <LOTW_QSL_RCVD:1>R <LOTW_QSL_SENT:1>Y <MODE:3>SSB <MY_COUNTRY:24>Fed. Republic of Germany <MY_CQ_ZONE:2>14 <MY_DXCC:3>230 <MY_GRIDSQUARE:6>JN39ml <MY_ITU_ZONE:2>28 <MY_RIG:12>ICOM IC-7300 <NAME:14>Jérémy Escrich <OPERATOR:5>DK9JC <OWNER_CALLSIGN:5>DK9JC <STATION_CALLSIGN:7>DK9JC/P <PROGRAMID:7>LOG4OM2 <PROGRAMVERSION:7>2.6.1.0 <QSLMSG:30>TU for the QSO. LOTW uploaded. <QSL_RCVD:1>R <QSL_RCVD_VIA:1>E <QSL_SENT:1>N <QSL_SENT_VIA:1>E <QSO_COMPLETE:1>Y <QSO_DATE:8>20200602 <QSO_DATE_OFF:8>20200602 <QTH:7>Frouard <RST_RCVD:2>59 <RST_SENT:2>56 <SWL:1>N <TIME_OFF:6>175331 <TIME_ON:6>175230 <TX_PWR:3>100 <K_INDEX:1>2 <LAT:7>48.7292 <LON:5>6.125 <MY_LAT:7>49.4792 <MY_LON:6>7.0417 <MY_ANTENNA:28>EFHW Mag Loop Outbacker-1899 <QSO_RANDOM:1>Y <SFI:2>69 <CLUBLOG_QSO_UPLOAD_DATE:8>20200602 <CLUBLOG_QSO_UPLOAD_STATUS:1>Y <MY_SOTA_REF:9>DM/SR-012 <APP_L4ONG_SATELLITE_QSO:1>N <APP_L4ONG_CONTEST:1>N <APP_L4ONG_QSO_CONFIRMATIONS:614>[{"CT":"EQSL","S":"Yes","R":"Requested","SV":"Electronic","RV":"Electronic","SD":"2020-06-02T00:00:00Z"},{"CT":"LOTW","S":"Yes","R":"Requested","SV":"Electronic","RV":"Electronic","SD":"2020-06-02T00:00:00Z"},{"CT":"QRZCOM","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"HAMQTH","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"HRDLOG","S":"Requested","R":"No","SV":"Electronic","RV":"Electronic"},{"CT":"CLUBLOG","S":"Yes","R":"No","SV":"Electronic","RV":"Electronic","SD":"2020-06-02T00:00:00Z"},{"CT":"QSL","S":"No","R":"Requested","SV":"Electronic","RV":"Electronic"}] <APP_L4ONG_QSO_AWARD_REFERENCES:172>[{"AC":"CDM","R":"F*","SUB":[],"GRA":[]},{"AC":"DXCC","R":"227","G":"EU","SUB":[],"GRA":[]},{"AC":"WAC","R":"EU","SUB":[],"GRA":[]},{"AC":"WAZ","R":"14","SUB":[],"GRA":[]}] <APP_L4ONG_MY_AWARD_REFERENCES:95>[{"AC":"SOTA","R":"DM/SR-012","G":"Germany (Low Mountains)","SG":"Saarland","SUB":[],"GRA":[]}] <EOR>
I wonder what the issue is here and where the 10m comes from. "Band RX" was not filled out during entering the QSO. The field was just blank.
Thank you for looking.
https://www.dk9jc.de
Re: Clublog: QSO shows "SATELLITE, INTERNET OR REPEATER" - RX band 10m
Hello John,
can confirm this error. Doing the same here and putting in a test qso with you at 2m SSB.
RX Band and RX Frequency are empty and CAT was off. Shows the same result at Clublog.
By the way, the test qso is deleted ....
DK9JC
Post by DK9JC »
DF5WW wrote: 03 Jun 2020, 15:20 can confirm this error. Doing the same here and putting in a test qso with you at 2m SSB.
I send you a QSL card for these data. :D Just kidding.
Thank you for the test.
I found the same problem for my CW qso with TT8SN.
FT8 from WSJT-X is no problem, everything works fine in Clublog.
Have a few provider problems with Skype at the moment but i´ve informed the team
via the beta testers board.
DK9JC
Post by DK9JC »
DF5WW wrote: 03 Jun 2020, 15:52 but i´ve informed the team
Danke Jürgen! :)
DK9JC
Post by DK9JC »
I could not resist to do some further investigation.
I deleted all the wrong entries in Clublog and exported a manual ADIF from Log4OM.
I then deleted <BAND_RX:3>10m in all ADIF entries and did a manual upload.
All is fine then:
The issue can be fixed when we find out where the 10m comes from.
Hi John,
looks like i found the problem. If you run Log4OM with CAT and disable CAT for manual logging
RX frequency is stepping to 0 but RX Band stays at latest used band. Have reportet this in the
Group and hope it´s easy to fix.
DK9JC
Post by DK9JC »
DF5WW wrote: 07 Jun 2020, 06:51 If you run Log4OM with CAT and disable CAT for manual logging
Good info. TU Jürgen. I just installed 2.7.0.0. but nothing about this issue in the release notes so I guess maybe next time.
it's under working in 2.8.0.0
DK9JC
Post by DK9JC »
IW3HMH wrote: 08 Jun 2020, 12:19 it's under working in 2.8.0.0
Very nice to hear and tu for feedback, Daniele. Ciao & 73
