Can this be done?
M7DJK
Can this be done?
Post by M7DJK »
I'm a new user so forgive if i have missed the instructions for this...
Is there a way to view the day's QSO's on one of the maps, like PSK reporter does, sort of thing??
I'm still trying to figure out what features i need to use/enable, no idea what clusters are for etc so lots to learn :D
Re: Can this be done?
M7DJK wrote: 21 Aug 2020, 10:45 I'm a new user so forgive if i have missed the instructions for this...
Map 1.jpg (133.69 KiB) Viewed 4983 times
Then
Map 2.jpg (98.4 KiB) Viewed 4983 times
M7DJK
Post by M7DJK »
Ok, thanks that will do it :)
Next Q....
Can it show the "lookup" results for the last imported QSO automatically?
Same as when you enter a callsign in the QSO area it loads and shows the data, can that be set for auto load/show on the latest QSO import??
M7DJK wrote: 21 Aug 2020, 14:28 Ok, thanks that will do it :)
Next Q....
Imported from where?
M7DJK
Post by M7DJK »
G4POP wrote: 21 Aug 2020, 15:00
Next Q....
Any connected source - WSJT-X, JS8Call, FLDigi etc
With the JT programs if you set it up as shown in the Log4om user guide the lookup is done and displayed in Log4om automatically as soon as the call sign is entered in the JT program
When the QSO is imported from Fldigi you need to right click on the QSO and select lookup, this action will open your browser and lookup the call
M7DJK
Post by M7DJK »
Ok thanks
M7DJK
Post by M7DJK »
G4POP wrote: 21 Aug 2020, 15:25 With the JT programs if you set it up as shown in the Log4om user guide the lookup is done and displayed in Log4om automatically as soon as the call sign is entered in the JT program
Can you expand on this please - its all connected now but there is no lookup when i click/work a callsign in WSJT ???
Assuming that you followed the set up instructions in the Log4OM user guide this will be the result
M7DJK
Post by M7DJK »
Thanks Terry, got it working now - i had the UDP_Incoming set to ADIF_MESSAGE not JT-MESSAGE.
WSJT now very happy :D
JS8Call not so happy, am I right that these settings only work for WSJT?
I fixed JS8Call by adding another inbound port and setting ADIF_Message as before so its going again now - I guess JS8Call does not do the super QSO lookup in the log when you work a station????
