LOG4OM and QRZ problem
ON4OM
Post by ON4OM »
When I introduce a call in log4om and press the earth map symbol on the windows right, I'm transferred in QRZ environnement ... all is ok until here
But if I want to add this call on my QRZ log, the date,hour, mode are well transfered but not the frequency
I precise that I followed the full instructions on page 97 of last english manual and I have a XML subscription in QRZ
Have you an idea?
Re: LOG4OM and QRZ problem
ON4OM wrote: 09 Oct 2020, 07:56 When I introduce a call in log4om and press the earth map symbol on the windows right, I'm transferred in QRZ environnement ... all is ok until here
Have you an idea?
OM,
The frequency is put in Log4OM V2 via the CAT connection to your rig. Of course, you could manually type it in from your keyboard as well.
Check you CAT connections.
ON4OM
Post by ON4OM »
The CAT work in log4om .. I see the frequency of the rig
But during the automatic transfer to QRZ environnement, all is transfer except this frequency value .. I must introduce it manually
Why?
ON4OM wrote: 12 Oct 2020, 16:32 The CAT work in log4om .. I see the frequency of the rig
Why?
OM,
Do a search here on the forum about QRZ uploads. I seem to recall a recent thread about QRZ. I think they change frequency to band only.
I've look at several OM sites on QRZ and they all show only the band ... no frequency.
Also ... do you have the API key that is needed for uploads to QRZ?
If you look at Page 97 of the most current User Guide it goes into detail about the API Key. You already noted you are an XML subscriber so that is good.
Again ... do a search on the Forum and you will likely find the thread about QRZ only posting band with uploads.
W4EBB
Post by W4EBB »
FYI - My QRZ Log shows band and frequency - see attachment
Charlie
W4EBB
W4EBB wrote: 13 Oct 2020, 12:05 FYI - My QRZ Log shows band and frequency - see attachment
Charlie
W4EBB
Charlie,
Tnx. That poses an interesting question. I just did a view of your QRZ this AM (I did log in) and it only shows band to me.
Go figure ?? !!
Shows frequency for me also, see below.
Did anyone think to ask ON4OM what Log4OM version he uses and what cat control (Hamlib or Omnirig)?
I have an old QRZ log in my profile and it also shows the frequency. That is just me looking at my own log.
I just choose to not display/use the QRZ log for day to day work.
When I view anyone else's log only the band shows up. I think that when looking at one's "own" log you get a different presentation of information.
I think the user is saying that Log4OM is not sending the frequency to QRZ and clearly IT IS with the latest release as evidenced by my log record shown.
So I need to have clarified.....
1. What version of Log4OM and CAT control is the user using so that we can make sure we are reading from the same page.
2. Has the user checked that in his actual log on QRZ (select my logbook from menu) the frequencies are shown or not
