LoTW
F6EXV
LoTW
Post by F6EXV »
Hi
Following previous message which remained unanswered, here is the situation.
On both the confirmation configuration, and the external services, I have configured the LoTW sent field to NO.
See the 2 pictures attached.
The upload upon exit is not done, despite the little message saying it is.
When I changed both to "Requested", it seams to work.
Is it normal that it does not work when both are set to "NO" ?
Thanks + 73
Re: LoTW
With NO settings does a manual upload from the QSL Manager work?
F6EXV
Re: LoTW
Post by F6EXV »
Yes
Thanks + 73
Paul F6EXV
Re: LoTW
What version of Trusted QSL and Log4om are you using
F6EXV
Re: LoTW
Post by F6EXV »
Log4OM version 2.9.0.0 and TQSL version 2.5.5, latest ones for both I think
Paul
Thanks + 73
Paul F6EXV
Re: LoTW
Have you tried turning on trace mode in the help menu and then closing log4om doing an auto upload to LOTW
Then reopen log4om and inspect the log file to see what happened last time you closed log4om?
F6EXV
Re: LoTW
Post by F6EXV »
The "last exception) box in the diagnostic form is empty after doing what you requested me to.
Thanks + 73
Paul F6EXV
Re: LoTW
Are you able to copy and paste the all of the lines from the log file that show records from the time you start to close log4om until it is completely closed on this forum?
F6EXV
Re: LoTW
Post by F6EXV »
No, they disappear too fast, I cannot make that little screen bigger, and I cannot stop the lines from moving up.
If there is a way to do both, I don't know how to.
Thanks + 73
Paul F6EXV
Re: LoTW
F6EXV wrote: 08 Nov 2020, 15:01 No, they disappear too fast, I cannot make that little screen bigger, and I cannot stop the lines from moving up.
Did you try saving the log file and then opening it in notepad?
You can make the window full screen as with all Win 10 windows
