Here is message in the dignostic page (sorry, in French)
08/11/2020 15:30:53 [TalkServer][#=zhOeEJDrKi3o9KMhCIA==] : [EXCEPTION] Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée
LoTW
Re: LoTW
That only tells meF6EXV wrote: 08 Nov 2020, 15:32 Here is message in the dignostic page (sorry, in French)
"No connection could be established because the target computer expressly refused it"
You did not have Trace mode turned on and you did not send me ALL of the lines from the start of close down to this point
However if you were actively refused it would seem that it was probably something set wrong in the Log4OM config most likely the station location is different to that in the TQSL program
You seem to be experiencing an abnormal level of problems, dont you have a local ham with PC knowledge that can assist you?
Re: LoTW
Hello again
I did some tests again, and... it looks like the upload upon exit now works. There is presently a few minute delay between uploading and showing on the LoTW site, but it is working.
I swear to god I have not touched any other parameter than the 2 mentioned earlier.
Sorry for taking your time, indeed.
Thanks + 73
Paul F6EXV
Paul F6EXV
