AM70URE/x
F6EXV
AM70URE/x
Post by F6EXV »
Hi all
When I imported a big adif file containing 55,000+ QSOs, some of the AM70URE calls had their DXCC and zones changed by Log4OM.
For info
AM70URE/6 is Balearic Islands, AM70URE/8 is Canary Islands and AM70URE/9 is Ceuta&Melilla.
Not sure where this wrong correction comes from, I think I have all the databases up-to-date.
Thanks + 73
Paul F6EXV
Re: AM70URE/x
It´s a problem of the guys who created this and/or don´t give any information for updating SCL lists.
AM70URE are counting for EA so any EAXxxx/6 will be stored as Balearic and any /8 or /9 as Canary
and Ceuta/Melilla.
Same dam´n thing is when guys working in the lighthouse events and hanging a /LH behind the call.
In that case country is set to Norway. Would be great if guys realise that extensions should be only the
correct ones. That means /AM, /M, /MM, /P and /A. All others could change the coutry where the
call is operated from.
F6EXV
Re: AM70URE/x
Post by F6EXV »
Juergen,
It would be Norway if the LH was before the callsign.
Years ago, when I operated from the US, I used F6EXV/W3. Today, I should use W3/F6EXV.
So the prefix is the country now, not the suffix. But the various programs have to deal with the old way and the new way, so it is not easy.
I just thought I woul let whoever can correct that.
Thanks + 73
Paul F6EXV
Re: AM70URE/x
As i said, it woldt be a problem if that callsigns are stored in the Special Callsign List and i think
we got it from Clublog (not shure). If so and all the special calls will be registered at clublog we
have it in the SCL and Log4OM can work with it.
By the way ... Call/W3 should set the country to USA and also W3/Call. In the past it was the thing
that the Prefix of the guest country stays ahead of the call. Meanwhile it´s behind but a lot of guys
like to entreing older contacts from paper logs. That means that the result should be the same.
Just when i writing this and have tried it wit my own call. Both resulting in United states and that´s
correct as it is ...
