Mode selection in main screen incomplete
DB9CR
Post by DB9CR »
Hello Log4OM-Support,
when I create a log entry on the main screen, under "Mode", I see only a short list of modes, including e.g. FM, but not e.g. DIGITALVOICE. After saving the log entry and opening it again, I can select from the full list of modes including DIGITALVOICE.
How can I make other modes available in the main screen?
Thanks, Christian DB9CR
Re: Mode selection in main screen incomplete
Did you modify the modes list in the program config?
DB9CR
Post by DB9CR »
No, did not modify anything.
My guess is that somewhere there is a filter defined what modes should appear in the short list on the main screen, while the edit funktion shows you the full list. But i cannot see where that is configured.
DB9CR
Post by DB9CR »
Under Configuration, Program Settings, Edit program Config, the "Edit progrram config" button is grey and nonfunctional.
DB9CR
Post by DB9CR »
modelist.csv contains all modes, there is no modelist_user.csv in %appdata%/Log4OM
//Log4om MODE;2.x MODE;3.x MODE;3.x SUBMODE
AM;AM;AM
AMTORFEC;AMTORFEC;TOR;AMTORFEC
ARDOP;ARDOP;ARDOP
ATV;ATV;ATV
C4FM;C4FM;C4FM
CHIP;CHIP;CHIP
CHIP64;CHIP64;CHIP;CHIP64
CHIP128;CHIP128;CHIP;CHIP128
CLO;CLO;CLO
CONTESTI;CONTESTI;CONTESTI
CW;CW;CW
PCW;PCW;CW;PCW
DIGITALVOICE;DIGITALVOICE;DIGITALVOICE
DOMINO;DOMINO;DOMINO
DOMINOF;DOMINOF;DOMINO;DOMINOF
DOMINOEX;DOMINOEX;DOMINO;DOMINOEX
DSTAR;DSTAR;DSTAR
FAX;FAX;FAX
FM;FM;FM
FSK441;FSK441;FSK441
FST4;FST4;MFSK;FST4
FT4;FT4;MFSK;FT4
FT8;FT8;FT8
HELL;HELL;HELL
FMHELL;FMHELL;HELL;FMHELL
HELL;HELL;HELL;FMHELL
HELL80;HELL80;HELL;HELL80
HFSK;HFSK;HELL;HFSK
FSKHELL;FSKHELL;HELL;FSKHELL
ISCAT-A;ISCAT;ISCAT;ISCAT-A
ISCAT-B;ISCAT;ISCAT;ISCAT-B
JT4A;JT4A;JT4;JT4A
JT4B;JT4B;JT4;JT4B
JT4C;JT4C;JT4;JT4C
JT4D;JT4D;JT4;JT4D
JT4E;JT4E;JT4;JT4E
JT4F;JT4F;JT4;JT4F
JT4G;JT4G;JT4;JT4G
JT6M;JT6M;JT56M
JT9;JT9;JT9
JT9-1;JT9;JT9;JT9-1
JT9-2;JT9;JT9;JT9-2
JT9-5;JT9;JT9;JT9-5
JT9-10;JT9;JT9;JT9-10
JT9-30;JT9;JT9;JT9-30
JT9A;JT9;JT9;JT9A
JT9B;JT9;JT9;JT9B
JT9C;JT9;JT9;JT9C
JT9D;JT9;JT9;JT9D
JT9E;JT9;JT9;JT9E
JT9E-FAST;JT9;JT9;JT9E FAST
JT9F;JT9;JT9;JT9F
JT9F-FAST;JT9;JT9;JT9F FAST
JT9G;JT9;JT9;JT9G
JT9G-FAST;JT9;JT9;JT9G-FAST
JT9H;JT9;JT9;JT9H
JT9H-FAST;JT9;JTH;JT9G-FAST
JT44;JT44;JT44
JT65;JT65;JT65
JT65A;JT65A;JT65;JT65A
JT65B;JT65B;JT65;JT65B
JT65B2;JT65B;JT65;JT65B2
JT65C;JT65C;JT65;JT65C
JT65C2;JT65C;JT65;JT65C2
MFSK;MFSK;MFSK
FSQCALL; FSQCALL;MFSK;FSQCALL
GTOR;GTOR;TOR;GTOR
JS8;JS8;MFSK;JS8
LSB;LSB;SSB;LSB
MFSK4;MFSK4;MFSK;MFSK4
MFSK8;MFSK8;MFSK;MFSK8
MFSK11;MFSK11;MFSK;MFSK11
MFSK16;MFSK16;MFSK;MFSK16
MFSK22;MFSK22;MFSK;MFSK22
MFSK31;MFSK31;MFSK;MFSK31
MFSK32;MFSK32;MFSK;MFSK32
MFSK64;MFSK64;MFSK;MFSK64
MFSK128;MFSK128;MFSK;MFSK128
MSK144;MSK144;MSK144
MT63;MT63;MT63
OLIVIA;OLIVIA;OLIVIA
OLIVIA4/125;OLIVIA4/125;OLIVIA;OLIVIA 4/125
OLIVIA4/250;OLIVIA4/250;OLIVIA;OLIVIA 4/250
OLIVIA8/250;OLIVIA8/250;OLIVIA;OLIVIA 8/250
OLIVIA8/500;OLIVIA8/500;OLIVIA;OLIVIA 8/500
OLIVIA16/500;OLIVIA16/500;OLIVIA;OLIVIA 16/500
OLIVIA16/1000;OLIVIA16/1000;OLIVIA;OLIVIA 16/1000
OLIVIA32/1000;OLIVIA32/1000;OLIVIA;OLIVIA 32/1000
OPERA;OPERA;OPERA;OPERA-QSO
OPERA-BEACON;OPERA-BEACON;OPERA;OPERA-BEACON
PAC2;PAC;PAC;PAC2
PAC3;PAC;PAC;PAC3
PAC4;PAC;PAC;PAC4
PAX;PAX;PAX
PAX2;PAX2;PAX;PAX2
PKT;PKT;PKT
FSK31;FSK31;PSK;FSK31
PSK10;PSK10;PSK;PSK10
PSK31;PSK31;PSK;PSK31
PSK63;PSK63;PSK;PSK63
PSK63F;PSK63F;PSK;PSK63F
PSK125;PSK125;PSK;PSK125
PSK250;PSK250;PSK;PSK250
PSK500;PSK500;PSK;PSK500
PSK1000;PSK1000;PSK;PSK1000
PSKAM10;PSKAM10;PSK;PSKAM10
PSKAM31;PSKAM31;PSK;PSKAM31
PSKAM50;PSKAM50;PSK;PSKAM50
PSKFEC31;PSKFEC31;PSK;PSKFEC31
QPSK31;QPSK31;PSK;QPSK31
QPSK63;QPSK63;PSK;QPSK63
QPSK125;QPSK125;PSK;QPSK125
QPSK250;QPSK250;PSK;QPSK250
QPSK500;QPSK500;PSK;QPSK500
SIM31;SIM31;PSK;SIM31
PSK2K;PSK2K;PSK2K
Q15;Q15;Q15
QRA64;QRA64;QRA64
QRA64A;QRA64A;QRA64;QRA64A
QRA64B;QRA64B;QRA64;QRA64B
QRA64C;QRA64C;QRA64;QRA64C
QRA64D;QRA64D;QRA64;QRA64D
QRA64E;QRA64E;QRA64;QRA64E
ROS;ROS;ROS
ROS-EME;ROS-EME;ROS;ROS-EME
ROS-HF;ROS-HF;ROS-HF
ROS-MF;ROS-MF;ROS;ROS-MF
RTTY;RTTY;RTTY;ASCI
RTTYM;RTTYM;RTTYM
SSB;SSB;SSB
SSTV;SSTV;SSTV
T10;T10;T10
THOR;THOR;THOR
THRB;THRB;THRB
THRBX;THRBX;THRB;THRBX
TOR;TOR;TOR
USB;USB;SSB;USB
V4;V4;V4
VOI;VOI;VOI
WINMOR;WINMOR;WINMOR
DB9CR wrote: 05 Dec 2020, 13:33 Under Configuration, Program Settings, Edit program Config, the "Edit progrram config" button is grey and nonfunctional.
Not sure what your looking at but that is not our menu, it should be as below
Perhaps if you post a screen shot of your program config we can workout what you are doing?
DB9CR
Post by DB9CR »
Ok, I was blind.. that's what I was lookign for. Thanks for pointing me into the right direction.
