Winkeyer interface
F6FLU
Winkeyer interface
Post by F6FLU »
My configuration is Log4OM and Ftdx5000
I would like to use Winkeyer ,
which interface do you use ?
and likewise which interface for the CAT system are you using ?
Many thanks for your comments
Dan - F6FLU
https://F6FLU.org
Re: Winkeyr interface
F6FLU wrote: 02 Feb 2021, 15:56 Hello,
Either a genuine K1EL Winkeyer USB or the G4ZLP version, I have both and they work fine
As for CAT control I thought the FT5000 provided a usb connection if so just a standard USB cable is all that is required.
N6VH
Post by N6VH »
Terry and Dan,
The 5000 doesn't have a USB connection, only a DB-9 CAT jack. The interface I use is the microHam microKeyer. It includes a Winkeyer, as well as an interface for RTTY, and audio between the rig and the computer. This particular model isn't made any more, but there are newer versions of it. I have used it for 14 years and the only problem was when a wire broke in the cable between the microKeyer and the rig.
Jim N6VH
F6FLU
Post by F6FLU »
Thank you for your comments, in fact I misspoke; I explain to you :
In fact here I am using an external box (made by a French OM) which includes a stereo sound card and 2 native FTDI ports
One FTDI port is used for the CAT (I use it for Omnirig and the CAT System)
the other is used for CW (DTR)
it works fine with Logger32 and Wintest but not with Log4OM which requires a Winkeyer type interface (K1EL)
my question is therefore more exactly what do you use to do CW and digital mode
Jim N6VH replied that he uses Microkeyer from Microham and I think this is the solution but it is very expensive ...
hence my question, maybe there is another cheaper system?
in any case thank you for your comments
Dan
Dan - F6FLU
https://F6FLU.org
Try the G4ZLP CW keyer its is a K1EL winkeyer emulation and we know it works fine and not too expensive
https://www.g4zlp.co.uk/unified/DigiMaster_CW.htm
F6FLU
Post by F6FLU »
OK Terry, Thanks but now G4ZLP said
"Orders to EU member states are currently suspended".....
Dan - F6FLU
https://F6FLU.org
Cest le vie
2E0YMT
Post by 2E0YMT »
G4POP wrote: 03 Feb 2021, 09:22 Try the G4ZLP CW keyer its is a K1EL winkeyer emulation and we know it works fine and not too expensive
I have the same and they do work ok, but im still having problems with macros the way I want them, I have tried spaces, dots to no avail...
G0UJA
Re: Winkeyer interface
Post by G0UJA »
FYI - I use an Arduino Winkeyer emulator by K3NG which works FB with Log4OM
2021-02-18 19.23.28.jpg (99.16 KiB) Viewed 11751 times
They're easy to build and setup with a total cost of around £10.
73 de James G0UJA
73 James G0UJA
f5nyy
Post by f5nyy »
Bonjour à tous,
je viens d'acheter un Keyer OPEN CW KEYER MK2 et j'ai émulé le NANO à l'intérieur avec
la source de K3NG, mais cela ne fonctionne pas.
Il se connecte bien à la KEYER Interface de LOG4OM mais autrement rien ne fonctionne.
Est ce quelqu'un a déjà utilisé ce matériel, si oui je suis preneur du fichier de compilation
pour voir ce qui manque ou ne va pas dans le mien.
Merci
Phil F5NYY
