CPU usage after starting Log4OM2
Re: CPU usage after starting Log4OM2
SV5FRI wrote: 19 Feb 2021, 15:49 Hi OMs,
I have the same problem with my cpu perfomance it is 57% as result to fence problem with FT8 decode (jtdx).
I have check it all the previous posts and all is find also i have disable and voadcap.
My pc is Laptop I7 with 8GB memory
Please for your advice
73 Yiannis, SV5FRI
As always the Log4om version number please! If you don't know how to find that it's shown in Help/about
SV5FRI
Post by SV5FRI »
Log4OM version is the latest 2.11
73 Yiannis, SV5FRI
http://www.sv5fri.eu
SV5FRI wrote: 19 Feb 2021, 16:27 Log4OM version is the latest 2.11
Then in the help menu set the debug mode to trace, use the program for 15 mins then send the log file to me by email
DO NOT POST THE LOG FILE HERE
SV5FRI
Post by SV5FRI »
I will upload log files tomorrow. i have notice that from the moment when have disabled it voacap the CPU usage is between 2 - 14%.
73 Yiannis, SV5FRI
SV5FRI
Post by SV5FRI »
After I had disabled and enabled again Voacap and make configuration the schedules every 1 hour now look fine.
My CPU performance for Log4OM is around 2 - 5 %
73 Yiannis, SV5FRI
SV5FRI
Post by SV5FRI »
The problem not solved remaining.
73 Yiannis, SV5FRI
SV5FRI
Post by SV5FRI »
Dear Terry,
I have send you with email the log files from my Log4OM
73 Yiannis, SV5FRI
SV5FRI wrote: 27 Feb 2021, 11:47 Dear Terry,
Appologies for the delay but I have been very busy.
Regarding your high processor demand
1. I note that Log4OM and probably WSJT are not being 'Run as an administrator' You need to change this for both programs and also Omnirig. - SEE PAGE 13>>> OF OUR USER GUIDE
2. What is the processor demand like if you only run Log4OM (WSJT and ALL OTHER SOFTWARE closed)
3. What cluster servers are you using?
4. Have you tried unchecking the boxes shown below and then clicking Save and apply button?
SV5FRI
Post by SV5FRI »
Don't apologies all we are busy.
My answer with red color.
G4POP wrote: 02 Mar 2021, 12:51
I will make this change and inform you for results
Is almost between 0 - 3% but the is same when I open WSJT, JTDX and ALL OTHER SOFTWARES. Also in theduring the operation of Log4oM the CPU usage will be increass at 90+% as result to stucking everything when I close the LOG4OM all back to normal and opening again.
I am using DxSpider dxc.sv5fri.eu port 7300
73 Yiannis, SV5FRI
SV5FRI
Post by SV5FRI »
hi
I Would like to inform you that after changes the same problem.
I have attach screenshot from task manager
73 Yiannis, SV5FRI
