CPU usage after running Log4OM ranges from 5 to 21% after moving and then stays at 45-50%, CAT off, I do nothing with the program.
OK, enough error information for now.
Others probably also have mistakes.
Greetings from Poland
where is the option TerryG4POP wrote: 17 Jan 2020, 12:27 Make certain that 'Trace mode' is not turned on in config, should just be 'Info'
Settings/Program Configuration/Program settings - 5th item down 'Default log level' should normally be set to 'Info'
OK thanks TerryG4POP wrote: 18 Jan 2020, 11:53Settings/Program Configuration/Program settings - 5th item down 'Default log level' should normally be set to 'Info'
