CPU usage after starting Log4OM2
Re: CPU usage after starting Log4OM2
please run a "performance check" and send me the results.
Performance check is in "program settings / performance" menu.
In order to pinpoint the issue can you turn off cluster and let me know if something changes?
slow performances may be related also to slow clusters that "keeps" log4om busy waiting for an answer.
Dear IW3HMH,
Below you can find the performance check
Performance test start on 10 calls...
Worked before...
20ms (202443 CPU cycles)
Sunrise/sunset check...
0ms (746 CPU cycles)
CQ Zone identification from Clublog database check...
15ms (157630 CPU cycles)
CTY Data checks...
6ms (67336 CPU cycles)
Callsign statistic search...
0ms (296 CPU cycles)
VOACAP test...
Calculated voacap data for FN21wa Max 0
Calculated voacap data for IN82eo Max 0
Calculated voacap data for KH02mt Max 0
Calculated voacap data for GF17sb Max 0
Calculated voacap data for FJ49gj Max 0
Calculated voacap data for CO46xp Max 0
Calculated voacap data for QO94jg Max 0
Calculated voacap data for ON26kl Max 0
Calculated voacap data for LP74jq Max 0
1073ms (10734698 CPU cycles)
External service search...
IW3HMH Daniele Pistollato
G4POP Terry Genes
LA9FFA Rolf Flaathe
NN7D Douglas R Munday
VA3AG Aldo Galati
KI5IO Nolan E Kienitz
OE6CLD Ing. Claus Stehlik
KD0ZV Rich R Mc Cabe
IQ3ME Associazione Radioamatori Italiani Sezione Di Mestre
2250ms (22504475 CPU cycles)
OVERALL Country statistic recalculation...
368ms (3685703 CPU cycles)
OVERALL Gridsquare statistic recalculation...
512ms (5125747 CPU cycles)
OVERALL Worked before statistic recalculation...
1ms (11322 CPU cycles)
Performance test COMPLETE
Worked before...
CTY Data checks...
VOACAP test...
G4POP Terry Genes
LA9FFA Rolf Flaathe
VA3AG Aldo Galati
- Capture1.PNG (8.22 KiB) Viewed 3645 times
I have disable cluster and enabled again same results
SV5FRI wrote: 03 Mar 2021, 11:16 hi
I Would like to inform you that after changes the same problem.
I have attach screenshot from task manager
Please for your advice
Hello SV5FRI
My computer HP Cpmpaq 8300 Processor Intel i5 8 GB RAM.
Server cluster GB7DXG-1 port 7300
Effect?
Screenshot
Greetings
SGC PowerClear, EMU0202
73!
Jan SQ9JXB
73!
Jan SQ9JXB
