EQSL not uploading anymore
Ab6kx
Post by Ab6kx »
I have been using Log4OM V2.11 with no issues for a couple of months and auto upload to both eqsl and lotw have been working great. of course lotw uploads on program close and eqsl has up to recently uploaded within a couple of minutes of a QSO. I get no error, I just see that QSL status is sent = N on recent qso. I can manually upload via Log4OM and download on demand so I know that the username and passwords are correct. Any assistance you can give would be great as I have loved this feature. See config below.
Re: EQSL not uploading anymore
You dont say what the upload log text reports in the upload window like the LOTW example below??????
But another way to check is as follows
1. Turn on trace mode in the help menu
2. Try another upload
3. Check the Log file in the help menu and that should show the error
Ab6kx
Post by Ab6kx »
Hello Terry,
just to clarify, there is no issue with manual uploads or downloads. the issue im having is that eqsl qso are not auto uploading as they have all along.
Ab6kx
Post by Ab6kx »
I opened the diagnostic page to see what happens after logging a qso and found this exception.
What are you using ADIF monitor for, WSJT, FLDigi or what?
Ab6kx
Post by Ab6kx »
Yes I am integrated with WSJT-X as well as Gridtracker. so wsjt sends to gridtracker and gridtracker to Log4OM. I come from a developer background so im comfortable with following any troubleshooting needs in case thats relevant :)
Ab6kx wrote: 21 Mar 2021, 00:48 Yes I am integrated with WSJT-X as well as Gridtracker. so wsjt sends to gridtracker and gridtracker to Log4OM. I come from a developer background so im comfortable with following any troubleshooting needs in case thats relevant :)
The question was, what is ADIF monitor selecting, perhaps state the ADIF monitor path or post a screen shot of the ADIF monitor set up window?
I ask because as I recall qso's derived via ADIF monitor are not automatically uploaded to the on line logs and there is no need to use ADIF monitor for WSJT its all done via UDP which does upload automatically.
Gridtracker logs to Log4OM as shown below, ADIF monitoring the WSJT ADIF file is not required!
Ab6kx
Post by Ab6kx »
here are my settings, and thanks for your help
Ab6kx wrote: 21 Mar 2021, 08:29 here are my settings, and thanks for your help
You should follow the prescribed set up and NOT use ADIF monitor
Either from our user guide or follow this set up https://www.k0pir.us/gridtracker-wsjt-x-and-log4om/
Ab6kx
Post by Ab6kx »
Thanks Terry I made the changes and its working again. Must have stopped when I installed gridtracker. Thanks for your help
