ive messed it up
g0osk
ive messed it up
Post by g0osk »
Sorry hope someone can help
i had to re-install windows fully on my pc,so i saved what i thought were the needed files from log4om2 to a memory stick
reset the pc and downloaded log4om2 and then copied over the files and open log4om2.
the problem i have is it opens at the sqlite page and if i click test it says the database is not valid.
Can i simply rename the database or open a new one and download my qso`s from qrz as an ADIF file
many thanks
colin
Re: ive messed it up
We're you using v1 or v2 before?
What happened to the log4om backup files
What part of the universe are you located, can't tell because you don't use your call sign for user name
g0osk
Post by g0osk »
Hi Terry
Sorry i should have used my callsign,ill set it up later
i`m G0OSK, using v2 stupidly i copied other files to the usb drive and now i not sure what is what.
It appears the backup folder is there but it is empty.
there are a few more files than shown on the pic if you need to see them
many thanks
colin
g0osk
Are you sure the backup folder is empty, not even containing a folder called 'historic?
Do you have Skype or TeamViewer on that pc?
g0osk
Post by g0osk »
Hi Terry
I have team viewer on here if that would be useful,though ou may need to help me run though it as i have not used it yet.
cheers
colin
Problem resolved on TeamViewer
Problem was that no backups had been saved anywhere so had to rebuild from a basic QRZ download
