Winkeyer - SPLIT
HB9ETR
Winkeyer - SPLIT
Post by HB9ETR »
Not sure if already noted...
Working split and using the winkeyer doesn't (or at least didn't for me) record the split when logging....ok if done without the winkeyer
v2.12 / Win10
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
Re: Winkeyer - SPLIT
HB9ETR wrote: 09 Apr 2021, 08:57 Hi Terry,
v2.12 / Win10
Rob,
Couple questions ... for your CAT control which APP are you using? Hamlib or Omnirig? If using Hamlib did you tic use Dual VFO box on the Hamlib interface?
HB9ETR
Post by HB9ETR »
Hi Nolan
I use Omnirig (as installed with the v2.12 which I recently re-installed)
K3 / Win4K3Suite / Log4OM v2.12
Rob
HB9ETR / G0IFL
