Not sure if already noted...
Working split and using the winkeyer doesn't (or at least didn't for me) record the split when logging....ok if done without the winkeyer
v2.12 / Win10
Winkeyer - SPLIT
Winkeyer - SPLIT
Rob
HB9ETR / G0IFL
Win10 i5-11400 @ 2.60GHz
HB9ETR / G0IFL
Re: Winkeyer - SPLIT
Rob,HB9ETR wrote: 09 Apr 2021, 08:57 Hi Terry,
v2.12 / Win10
Couple questions ... for your CAT control which APP are you using? Hamlib or Omnirig? If using Hamlib did you tic use Dual VFO box on the Hamlib interface?
Hi Nolan
I use Omnirig (as installed with the v2.12 which I recently re-installed)
K3 / Win4K3Suite / Log4OM v2.12
Rob
HB9ETR / G0IFL
HB9ETR / G0IFL
