Hi guys,
since I updated the worked countries continue to appear in red. For example, I recently connected Mali in 20m and the same station should appear in gray on the same band. Instead it continues to appear red to me as if it were a new one.
Advice?
Worked in red
Re: Worked in red
When you say worked do you mean an ssb or cw with you adding the qso manually
Or
A QSO coming from external software like ft8 from WSJT or psk from Fldigi?
Or
Re: Worked in red
I worked it on 20m SSB now it still gives me red (TZ4AM).
I closed and restarted log4om but it is always red and is, obviously, present in the LOG (also on QRZ and LOTW)
Max IK0TIX
Max IK0TIX
Re: Worked in red
I am attaching photos
- Cattura3.JPG (52.37 KiB) Viewed 3317 times
- Cattura2.JPG (41.18 KiB) Viewed 3317 times
- Cattura.JPG (43.2 KiB) Viewed 3317 times
Max IK0TIX
Max IK0TIX
Re: Worked in red
Does it show as worked in the awards statistics/DXCC?
In the program config/performance tab make sure all three boxes are checked
Check your cluster filters are set to worked and not some sort of confirmation like LOTW
Re: Worked in red
Hi Terry, thanks for the answer
I try it but nothing change, this time with Iran:
- Cattura2.JPG (15.61 KiB) Viewed 3293 times
- Cattura1.JPG (16.43 KiB) Viewed 3293 times
- Cattura.JPG (87.16 KiB) Viewed 3293 times
Max IK0TIX
Max IK0TIX
Re: Worked in red
Hi Terry, I solved it and you were right but I didn't understand which cluster filter you were referring to.
In the attached image I used the correct one. Now everything is ok but something no normal happens anyway. When I close and reopen Log4OM, the filter sets me back to LOTW instead of WORKED. Some advice?
- Cattura.JPG (89.07 KiB) Viewed 3276 times
Max IK0TIX
Max IK0TIX
Re: Worked in red
Max,IK0TIX wrote: 02 May 2021, 20:29 Hi Terry, I solved it and you were right but I didn't understand which cluster filter you were referring to.
Filter setup is at: Settings / Program Configuration / Confirmations ... once you make adjustments be sure to tap "Save and apply"
Rescan Awards: View / Awards status / Maintenance tab ... once you have selected the Award you are working with.
