I've just upgrade to 2.13 and the refreshing seems to be very long : 1'31" Back to 2.12 same refresh : 14"
I didn't make test with the portable edition.
I have the same results (not exacly the same time) on 3 differents computers.
Is it only at my QTH or is someothers have the same problem?
73 de f5mxh
A way long Refreshing on V2.13
Re: A way long Refreshing on V2.13
Same result if:
- You hit the refresh button,
- After external loging (ie: jtdx or wsjt).
1: push this button
2: refreshing
1: push this button
2: refreshing
- image_2021-05-01_121726.png (44.3 KiB) Viewed 4228 times
In the program config/performance tab try unchecking the three check boxes and see if that improves things
Nothing significant!
In the config performance tab carry out a performance check and email it to me please
The result:
Performance test start on 10 calls...
Worked before...
946ms (9468190 CPU cycles)
Sunrise/sunset check...
2ms (25866 CPU cycles)
CQ Zone identification from Clublog database check...
17ms (174067 CPU cycles)
CTY Data checks...
8ms (87812 CPU cycles)
Callsign statistic search...
4ms (46717 CPU cycles)
VOACAP test...
Calculated voacap data for FN21wa Max 0
Calculated voacap data for IN82eo Max 0
Calculated voacap data for KH02mt Max 0
Calculated voacap data for GF17sb Max 0
Calculated voacap data for FJ49gj Max 0
Calculated voacap data for CO46xp Max 0
Calculated voacap data for QO94jg Max 0
Calculated voacap data for ON26kl Max 0
Calculated voacap data for LP74jq Max 0
1795ms (17959099 CPU cycles)
External service search...
IW3HMH Daniele Pistollato
G4POP Terry Genes
LA9FFA Rolf Flaathe
NN7D Douglas R Munday
VA3AG Aldo Galati
KI5IO Nolan E Kienitz
OE6CLD Ing. Claus Stehlik
KD0ZV Rich R Mc Cabe
IQ3ME Associazione Radioamatori Italiani Sezione Di Mestre
2001ms (20019012 CPU cycles)
OVERALL Country statistic recalculation...
33655ms (336553992 CPU cycles)
OVERALL Gridsquare statistic recalculation...
30557ms (305570076 CPU cycles)
OVERALL Worked before statistic recalculation...
0ms (187 CPU cycles)
Performance test COMPLETE
Worked before...
CTY Data checks...
VOACAP test...
G4POP Terry Genes
LA9FFA Rolf Flaathe
VA3AG Aldo Galati
If you compare my performance test with your one you will see that your results are extremely slow in comparison for virtually every function, this would indicate a local issue rather than a Log4OM problem, what PC are you using and what internet connection speeds do you have?
The size of database will have a small effect I am using a database with just over 20K QSO's
Worked before...
16ms (161476 CPU cycles)
0ms (8222 CPU cycles)
7ms (73992 CPU cycles)
CTY Data checks...
2ms (29731 CPU cycles)
2ms (24612 CPU cycles)
VOACAP test...
464ms (4647882 CPU cycles)
G4POP Terry Genes
LA9FFA Rolf Flaathe
VA3AG Aldo Galati
1832ms (18326371 CPU cycles)
958ms (9586253 CPU cycles)
984ms (9847192 CPU cycles)
0ms (147 CPU cycles)
Worked before...
CTY Data checks...
VOACAP test...
G4POP Terry Genes
LA9FFA Rolf Flaathe
VA3AG Aldo Galati
The Test PC is a core i7 with 32GO of memory and 1TO of SSD.
I do not have this problem on the v2.12. I will stay in the v2.12 at the moment...
Thierry f5mxh
Thierry f5mxh
Same specification as my pcf5mxh wrote: 03 May 2021, 14:03 The Test PC is a core i7 with 32GO of memory and 1TO of SSD.
Thierry f5mxh
Pity you have reverted to 2.12 as I would have liked to find the reason for this, never mind!
