I'm using the intermediate build 2.13.0.3 which you sent me re the awards issue.
I notice that with this build, it sends/uploads my LOTW log/adif file to LOTW without issue.
But now, with this build, it does not go back and mark the QSOs Sent. They remain 'requested'. I have to manually go and update them sent. Whereas previously, a restart of LOG4OM showed them as sent.
regards
Alan
PS - it also keeps reminding me that 2.13.0.0 (an earlier build) is ready for download.
V 2.13.0.3 LOTW not marked as sent
Re: V 2.13.0.3 LOTW not marked as sent
I can confirm this for 2.13.0.3. Also not sended after close. A manual upload from
QSL Manager works fine. Automatted upload on close is set, no changes to earlier
versions.
Have a lot problems with Skype so can´t inform the Team via this way at the
moment but shure that Terry reads this.
versions.
Alan,VK2MET wrote: 20 May 2021, 03:16
That prompt is SOP when we're working on the Alpha versions. It will continue until the program is finaled for a full release.
BTW - you can also turn off the "Check for Updates" at: Configuration / Program Settings
ok thanks no probs
