N1MM interaction
HB9ETR
N1MM interaction
Post by HB9ETR »
Acknowledging that the contest interface is currently removed....on testing in prep for the IARU HF test today...the SRx and STx aren't (for me at least) importing correctly...I just get a tally for the SRx and a 0 for the STx.
Is this because the contest interface is out or is it not working in the way I thought it might?
Rob
HB9ETR / G0IFL
K3/Win4K3Suite/OnmiRig/L4OM v2.33.0.0
Win10 i5-11400 @ 2.60GHz
Re: N1MM interaction
HB9ETR wrote: 10 Jul 2021, 07:40 Hi,
The contest mode is working its now integrated into the main UI instead of a separate window
HB9ETR
Post by HB9ETR »
Tnx terry
I must have something wrong then!
I have followed the guide (configured the contest in the settings) and when I either try to invoke the contest mode from the menu bar or from the crown, i see no difference. A red bar flashes saying "refreshing" but no contest entry page (or change to the main UI). This is the same from the Winkey page too.
Any ideas?
Rob
HB9ETR / G0IFL
HB9ETR
Post by HB9ETR »
sorry
v 2.15.0
Win10 i7-6700
K3 - Win4K3Suite - OnmiRig
Rob
HB9ETR / G0IFL
HB9ETR wrote: 10 Jul 2021, 10:44 Tnx terry
Any ideas?
Have you set the contest dates correctly in the Contest settings, I have just tested and it works fine as below in main UI and Winkeyer
Untitled (FILEminimizer).jpg (128.58 KiB) Viewed 3421 times
Untitled2 (FILEminimizer).jpg (112.68 KiB) Viewed 3419 times
HB9ETR
Post by HB9ETR »
Screenshot 2021-07-10 131257.png (11.51 KiB) Viewed 3419 times
i think that's correct.
Then when I press the crown....nothing
Rob
HB9ETR / G0IFL
HB9ETR wrote: 10 Jul 2021, 11:13 Screenshot 2021-07-10 131257.png
Rob,
Terry noted above to check the start and end dates in your contest setup.
The screen clip you posted indicates the contest won't be starting until October 27, 2021.
Open up dates say from first of this year to end of this year and give that a try.
You posted this screen shot before the start time of the contest today so of course it wont start the contest window, try changing the start time to 00.30 hrs
KI5IO wrote: 10 Jul 2021, 12:16
Rob,
Nolan,
Date format shown is European Day/Month/ Year like 10th July (07)
HB9ETR
Post by HB9ETR »
Seems on my system a right click on the crown is not good enough.....needs to be a right click/hold to turn it all green.
All working now.
tnx for fb
Rob
HB9ETR / G0IFL
