size of logbook
size of logbook
is there a way to edit the size of the logbook? perhaps to just show the last 50 qso's? otherwise the log book encroaches on the call sign/qso box above it overlapping some of that.
Re: size of logbook
Phil,
I'm not understanding exactly what you are asking. If you have the Main UI open and selected Recent QSOs (F7) there is no way for that 'logbook' to encroach/cover up the callsign field in the Main UI.
Screen clip below is what my installation looks like with the recent QSOs logbook tab selected.
I'm sure I'm not grasping what you are looking at or needing. Some screen clips would be extremely helpful.
- RecentWSOs_MainUI-medium.JPG (112.98 KiB) Viewed 2036 times
Re: size of logbook
I was having trouble doing a print screen so I saved it in word. I hope this shows what I mean
PRINT.docx
- (187.1 KiB) Downloaded 128 times
Re: size of logbook
Phil,
I have absolutely no clue as to how you are able to make that happen. There are not any toggles, switches or setups to even allow that to happen with normal use of Log4OM V2.
Also ... I see you have V2.17.0.0 installed. The most current release is: V2.19.0.0
Are you running Log4OM V2 in or on a Windows PC? If so what O/S?
The screen clip I provided is what a normal screen will look like. There is no way to collapse the panel tabs and have that lower panel overlap the upper Main UI section.
Download and install V2.19.0.0 and see if the installation will help correct something that looks to be messed up.
I've made a screen clip of what you sent me and have added it to this post.
- k2jf_MainUI.JPG (165.54 KiB) Viewed 2032 times
Re: size of logbook
Hi Nolan
I downloaded the new version and still have the same issue with how the log appears.. I'm attaching what I just got after the update.
PRINT.docx
- (187.38 KiB) Downloaded 152 times
Re: size of logbook
Have you set your windows system/display/customised scaling to something other that 100%?
Re: size of logbook
Yes, I scaled it all the way down to 50% and it hardly changed. I haven't been on the air for 2 months but I do remember that when I was last on I was able to see the full form.
Re: size of logbook
Phil,
Just a thought process here. In the past two months (for example) my Windows 10 Pro O/S has had at least two if not three updates from MSoft.
It is possible that some drivers may have been tweaked as part of those updates. Maybe take a look there as well.
Re: size of logbook
I just did an MS update and still the same issue. It's not a deal breaker because I still like the logging program among all the others I've tried.
Re: size of logbook
Phil,
Tnx for that, but you are not getting the full benefit, use and display of Log4OM V2. Something is not right.
You should consider generating a Support Request at: Help / Generate Support Request
That will provide some basic data from your installation and maybe a hint as to what is up or wrong in this case.
