Log4OMV2 ver. 2.18.0.0 cannot upload to LoTW
OX3XR
Re: Log4OMV2 ver. 2.18.0.0 cannot upload to LoTW
Post by OX3XR »
Hello DF5WW,
I will have a .NET update done and see if that helps. Will report back.
Brgds
Peter
OX3XR
PeterOX3XR wrote: 29 Jan 2022, 12:36 Log4OM V2 ver. 2.19.0.0, 230122.jpgNolan,
I have installed Log4OM V2 rev. 2.19.0.0
There are still problem uploading to LoTW. Apparently it does not create an ADIF file.
It was possible (suddenly) to upload with ver 2.18.0.0 on Jan. 23. However, with 2.19.0.0 there is a problem generting the ADIF file which must contain app. 70 QSO's.
I have attached a screenshot showing the error message.
Brgds
Peter
OX3XR
Did you set a temp folder for LOTW in the Log4OM config, if so what is the full path to the folder
nd1x
Post by nd1x »
Same problem with Upload to LOTW, TQSL is updated. LOTW password is okay. temp file is okay. With ver. 2.19 when I shut down Log4OM is does not finish the process. I have to close the program manually and then If I try to restart, I can't, being I have to go into task manager and shut it down then I can restart. I did not have this problem with the previous update. It would shut down completely and all was well, Not the case with 2.19?
Tnx, John
ND1X
Have you tried disabling auto upload for LOTW? and see if it closes OK
nd1x
Post by nd1x »
Yes, that did close log4om like always. But the auto upload on previous version was checked and it worked okay? So my other questions is, if it does not auto upload after closing will at some point the log get uploaded to LOTW? I am guessing it will ?
Tnx, John
ND1X
Now please try a manual upload to LOTW
nd1x
Post by nd1x »
Yes, manual upload worked well.
Tnx, John
ND1X
nd1x wrote: 09 Feb 2022, 19:26 Yes, manual upload worked well.
Tnx, John
ND1X
And I assume the program closes cleanly now?
If so please email me at g4pop (AT) arrl.net please
OX3XR
Post by OX3XR »
PeterOX3XR wrote: 31 Jan 2022, 23:41 Hello DF5WW,
Brgds
Peter
OX3XR
Hello DF5WW,
.NET Framework update report that I have Ver. 4.8 or newer.
I use only manual upload to LoTW. The file reported (see screenshot, yellow marking) is not found in the temp folder.
Log4OM V2 Rev. 2.19.0.0 no LoTW upload.jpg (43.42 KiB) Viewed 2704 times
.NET Framework 4.8 installed.jpg (25.94 KiB) Viewed 2704 times
OX3XR
Post by OX3XR »
Hello all,
I have installed Log4OMV2 ver. 2.20.0.0, and I have NET version 4.8.04084 installed. I still have problem with uploading to LoTW.
Log4OMV2 ver. 2.20.0.0 does apparently not save the adif file as previously informed.
What is next step in this troubleshooting?
Brgds
Peter
OX3XR
NET ver. .jpg (96.85 KiB) Viewed 2618 times
