Missing Lat and Lon data
M0XYG
Post by M0XYG »
I notice that only some stations are being logged with Long and Lats at the time of the QSO. However, manually highlighting the records in the QSO manager, then clicking the 'update info' button to get info from external sources that action populates the Lat and Lon field properly.
Should this be an automatic filled field at the point of logging as it seems to do some but not all?
Attached shows before and after update info button used.
LAT and Long missing.pdf
(103.34 KiB) Downloaded 87 times
Re: Missing Lat and Lon data
Your correct - It should, it did but it dont now!
M0XYG
Post by M0XYG »
Hi Terry, Awesome.
I thought it should've, I see it did, but it don't now, will it ever again?
:D
Yes when we fix it
