"Statistics & Awards" fails to open
VE3VEE
Post by VE3VEE »
Version 1.17.00.00 fails to open: Menu > Utilities > Statistics & Awards
73 Marvin VE3VEE
Re: "Statistics & Awards" fails to open
Are you sure it is not hidden behind the main window?
VE3VEE
Post by VE3VEE »
In previous versions it used to open behind the main window most of the time, but in this version it fails to open. I restarted the application, and I even restarted my laptop (Windows 7), but nothing helped. Does it work properly on your end?
73 Marvin VE3VEE
Yes Marvin it does.
You did uninstall the old version first didn't you?
Could be a bad download or install try removing Log4om and deleting the download then download a fresh file and reinstall it
VE3VEE
Post by VE3VEE »
Terry, that did it! Thanks! Now it works :-)
73 Marvin VE3VEE
You must always uninstall Log4om before installing an updated release because windows sometimes cache a DLL and this can cause unpredictable results such as windows that don't open and similar issues
VE3VEE
Post by VE3VEE »
Terry, I will try to remember, but I'm sure a few updates down the road I will again do the same mistake... :-) Perhaps the installer should uninstall previous version before proceeding with the installation of a new version.
73 Marvin VE3VEE
There is a pop up window that warns you about that
VE3VEE
Post by VE3VEE »
Never noticed it ... that's how much I pay attention to installation instructions (as little as the other guy ;) ) ...
By the way, happy World Amateur Radio Day to all.
73 Marvin VE3VEE
