Just upgraded my LOG4OM and noticed that a station already worked on the same mode on the same band was correctly signalled with message "worked same mode same band".
On this new version I only get message "worked same mode" and "same band" is not signaled.
V 2.21.0.0 worked same band not signalled
73 de I0MOM Marco
Re: V 2.21.0.0 Cluster K.O.
Buonasera.
Confermo quanto detto sopra da I0MOM e aggiungo che :
Con la nuova versione , il cluster è impazzito , la lista dx è sempre ferma su una schermata , la prima che ha caricato, poi si aggiorna in un battito di ciglia ,fa vedere x qualche millisecondo la lista cambiata e ritorna sulla prima schermata.
A dire il vero gia dalla precedente versione ho notao anomalie nel cluster sempre inerenti allo stesso problema ,ma non cosi gravi.
73 Marcello IZ7DJS
73 Marcello IZ7DJS
Re: V 2.21.0.0 worked same band not signalled
Greetings, I have noticed the same as problem as I0MOM with the new version. If the worked before tab is pressed it shows the station as being worked on band and mode but not on the home screen.
Regards, Roger K1WNT
I have found exactly the same problem after installing version 2.21
Optibeam OB 9-5
Optibeam OB 9-5
Checking that, thanks for head up. Nothing was reported by testers on that.
Thanks!
i have some additional information for you.
during my test yesterday I saw that a new QSO which I saved then did get the correct cluster status.
The QSO's already present in my database get the wrong status in the cluster view if the station in question has a cluster entry.
I use LOG4OM daily from about 10:00 in the morning until late in the evening / midnight because of the beautiful cluster display and the alarmsettings that I have set to monitor specific stations like for example all WRTC (II0WRTC, II1WRTC, etc) stations. Because of this, I immediately noticed that the cluster status is not displayed in the correct color. Normally I can immediately see by the color if I have worked a station on the particular band with the particular mode, this is perfect.
If I can contribute to this nice software I would like to make myself available as a tester.
- Cluster colors.png (34.79 KiB) Viewed 2993 times
Optibeam OB 9-5
Optibeam OB 9-5
Hi Dick,
we have a DISCORD channel where everyone can join the beta team (you need to download DISCORD APP)
https://discord.gg/kbwvX4HfTS
I will release soon a new beta with the fix, and then a 2.20.1.0 release in hotfix. BETA version will be available in the usual download page
there is a new beta version available for testing before we release 2.21.1.0 hotfix
Thanks Daniele,
I just installed Discord via the link and will see how i have to use it, because Discord is new for me.
I also installed the Beta 2.21.1.1 it did not fix the problem for me. it is still showing the wrong color
Optibeam OB 9-5
Optibeam OB 9-5
Daniel, Just tried BEta this afternoon , seems to be working fine. Thanks you for the quick fix and the best logging program.
73, Roger K1WNT
73, Roger K1WNT
