Could there be an option in "Select Band" to "Follow Source"?
Then when you change band, the VOCAP presentations would always pertain to the band that you are currently actively using.
VOCAP Data window
Re: VOCAP Data window
It already does this if band changes in input window and there is a manual selection in the Propogation window so I dont understand your request
If I use View > Propagation to get a standalone window, that window does not follow the bandswitch.G4POP wrote: 11 Apr 2022, 09:07 It already does this if band changes in input window and there is a manual selection in the Propogation window so I dont understand your request
You are correct the floating propogation window does not follow the radio band.K0HB wrote: 14 Apr 2022, 20:36
Your request should have read ..........
'In the Detached propogation window selected from the view menu could there be an option in "Select Band" list to "Follow CAT"?'
That would have been clearer to my ancient brain
