VOCAP Data window
K0HB
VOCAP Data window
Post by K0HB »
Could there be an option in "Select Band" to "Follow Source"?
Then when you change band, the VOCAP presentations would always pertain to the band that you are currently actively using.
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
Re: VOCAP Data window
It already does this if band changes in input window and there is a manual selection in the Propogation window so I dont understand your request
K0HB
Post by K0HB »
G4POP wrote: 11 Apr 2022, 09:07 It already does this if band changes in input window and there is a manual selection in the Propogation window so I dont understand your request
If I use View > Propagation to get a standalone window, that window does not follow the bandswitch.
DE Hans, KØHB
K0HB wrote: 14 Apr 2022, 20:36
You are correct the floating propogation window does not follow the radio band.
Your request should have read ..........
'In the Detached propogation window selected from the view menu could there be an option in "Select Band" list to "Follow CAT"?'
That would have been clearer to my ancient brain
