hello, has anyone using flaxradio managed to see the two vfo frequencies in log4om?
what configuration you need to do
thanks
frequencies of the 2 VFOs
Re: frequencies of the 2 VFOs
That does not work but it has been requested.
Only way to do that is to assign rig 1 and rig 2 in OmniRig to the two Flex CAT connections, thats one of the reasons why I sold my flex and went to SunSDR with the excellent TCI interfaceiz2rlo wrote: 16 Apr 2022, 15:03 hello, has anyone using flaxradio managed to see the two vfo frequencies in log4om?
thanks
That doesn't seem to work Terry. It should, but I have yet to make that function. SmartSDR cat shows OmniRig connected to both ports/slices but Log4om still does not seem to work.G4POP wrote: 20 Apr 2022, 22:33 Only way to do that is to assign rig 1 and rig 2 in OmniRig to the two Flex CAT connections, thats one of the reasons why I sold my flex and went to SunSDR with the excellent TCI interface
It does if you switch from rig 1 to rig 2, or it did for me when I owned a Flex
Dont expect to see both VFO frequencies at the same time you need to switch in Log4OM
Terry will not switch on mine. I have had a few times over the years where both VFOs actually showed up momentary but did not last and that was encouraging. But I cant switch back and forth.
This is not a Flex issue. This is a log4OM issue. The slices are on 2 different com ports. HamLib works so much better for the Flex but you have to start all your software in a certain order. Doing all this testing I got tired of shutting down everything and restarting.
I am sure its capable of doing both slices on the Flex if Lele would choose to.
Note selector on both images and which slice shows up in Log4OM
- 2222.jpg (174.51 KiB) Viewed 2855 times
- 1111.jpg (139.1 KiB) Viewed 2855 times
Well if I knew what SDC was, I would try it
Thank you guys for your help,
if the problem is lo4om let's hope they fix it,
let's see if someone has solved
73 Cris iz2rlo
73 Cris iz2rlo
