DXCC Entity for Queens Platinum Jubilee NoV Callsigns
MM0GOR
Post by MM0GOR »
Team
In QSO details tab, my NoV callsign MQ0GOR for The Queen's Platinum Jubilee in June 2022 is showing as DXCC entity England and should be Scotland DXCC#279 - can you please help to get this changed as it is affecting my LOTW uploads?
My QTH/Station Country/
Gordon
MM0GOR
MQ0GOR
Re: DXCC Entity for Queens Platinum Jubilee NoV Callsigns
MM0GOR wrote: 06 Jun 2022, 12:56 Team
Gordon
MM0GOR
MQ0GOR
Gordon,
Do you have Clublog enabled for use as an Info Provider in your Configuration?
When doing a lookup with your MQ0GOR call it will show up as Scotland when Clublog is enabled.
I seldom use Clublog and would have expected your call to resolve properly with just QRZ as the data is proper there, but for some reason Log4OM won't let it resolve via just that Info Provide source.
Gordon
MM0GOR
MQ0GOR
The LOTW uploads can only be affected if you have not got the following correct
No MQ???? Cert from LOTW
Wrong user name (Callsign) in the external services/LOTW section of the Log4OM config
You have not modified the station call in station info menu of Log4OM config and of course the country
ALL THREE OF THE ABOVE MUST BE CORRECT
MM0GOR
Post by MM0GOR »
Terry
Thanks for the response:
Station callsign is MQ0GOR in the Station Information tab
My LOTW certificate is correct as MQ0GOR DXCC#279 Scotland - LOTW External services setup is okay
My LOTW username is MM0GOR and I have multiple callsign certificates under that username, also working okay with LOG4OM and LOTW upload/downloads
Could the issue be that LOG4OM is using QRZ.com as a lookup for callsign prefixes in the Station Information tab, where QRZ.com has not listed "MQ" under DXCC entity Scotland?
Gordon
MQ0GOR
But your refering to uploading your QSO's to LOTW so QRZ has nothing to do with it, only used to check the other station details not yours!
What does the LOTW upload error say?
MM0GOR
Post by MM0GOR »
Terry
It seems that it's JTDX causing the issue as DXCC entity on there is England and not Scotland with the MQ prefix.
Gordon
MQ0GOR
