WSJT-X log time always 00:00:00
ta2bny
Post by ta2bny »
Hello all,
When recording a FT8 qso from WSJT-X, time is always logged as 00:00:00.
Could not find a solution for this.
Any help would be appreciated.
ta2bny
Re: WSJT-X log time always 00:00:00
Post by ta2bny »
Just set up a new computer. Made a clean install. Still the same problem.
Wsjtx_log.adi file shows correct times. Log4om still shows imported qso time as 00:00:00.
Log4om and WSJT version number ?
ta2bny
Post by ta2bny »
all latest;
Log4om: 2.23.0.0
WSJT_X: 2.5.4 d 28164
How are the qso's being sent to Log4om ?
A. ADIF monitor
B By UDP
ta2bny
Post by ta2bny »
On WSJT-X settings, UDP server is checked, not ADIF broadcast.
On LOG4OM settings, JT_message ( port 2237) and application settings, JT message #12 is checked
ta2bny
Post by ta2bny »
settings are like this:
Ekran görüntüsü 2022-07-03 222720.png (50.73 KiB) Viewed 4078 times
Ekran görüntüsü 2022-07-03 222701.png (63.31 KiB) Viewed 4078 times
Ekran görüntüsü 2022-07-03 222447.png (125.87 KiB) Viewed 4078 times
Anyone else seeing this because I can't emulate it?
ta2bny
Post by ta2bny »
adi file and LOG4OM QSO page is like that: ( the only time correct line is entered manually)
I am using windows 10 Turkish language version, programs are English. Could there be a language conflict problem? This is the only thing I could think of. Think I tried every possible scenerio...
Ekran görüntüsü 2022-07-03 224740.png (130.68 KiB) Viewed 4074 times
Ekran görüntüsü 2022-07-03 224707.png (117.9 KiB) Viewed 4074 times
ta2bny
Post by ta2bny »
Hello again,
My problem still continues. During this time I logged all qso's manually. Then I realised that log4om adif export is problematic for me. Wen it sends reports to qrz.com time is shown as 00:00, also reporting to LOTW via TQSL, time is seen as 00:00 so it halts. Log4om adif export file seems fine though.
I am very stuck around this.
Yeni Resim.jpg (213.61 KiB) Viewed 3346 times
