Hi
I have a problem, Hamlib disconnect afte a second or two, here is the log.
What I am doing wrong?
11.13.49.838 Info: [#=z7JzcX$MZ9e8ZCrJd2g==] : [CAT START] by CAT usercontrol
11.13.49.839 Info: [#=zNDKAT964ZDXYtbBl4Q==] : [HAMLIB] Starting Hamlib service
11.13.49.841 Info: [#=zNDKAT964ZDXYtbBl4Q==] : [HAMLIB] Using existing connection: False
11.13.49.843 Info: [ProgramStorage] : [CAT STATUS CHANGED] Running: True
11.13.49.988 Info: [#=zNWAIyI4=] : [HAMLIB] DAEMON STARTED: C:\Log4OM2_2_23_0_0_portable\Portable\config\hamlib\rigctld.exe --model=2036 --rig-file=127.0.0.1:7820 -Z --vfo
11.13.52.093 Info: [#=zNWAIyI4=] : [HAMLIB] Hamlib Process exit code: 2
11.13.52.103 Info: [#=zNWAIyI4=] : [HAMLIB] DAEMON STOPPED. Hamlib instance terminated
11.13.52.983 Error: [HamlibEngine][#=zWApzMZA5Z8gD$sSK9pwMVq0=] : [EXCEPTION] No connection could be made because the target machine actively refused it 127.0.0.1:4532
11.13.52.993 Info: [HamlibEngine] : [HAMLIB] Stop polling. Timeout True
11.13.52.999 Info: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
73's,
OH6PP Pena
Hamlib does not stay connected
Re: Hamlib does not stay connected
Known issue which is to be resolved for the next release
HI
Thans for the quick response. No need to struggle with this problem anymore
Any idea when next release will be out?
73's,
OH6PP Pena
73's,
OH6PP Pena
