Hamlib does not stay connected
OH6PP
Post by OH6PP »
Hi
I have a problem, Hamlib disconnect afte a second or two, here is the log.
What I am doing wrong?
11.13.49.838 Info: [#=z7JzcX$MZ9e8ZCrJd2g==] : [CAT START] by CAT usercontrol
11.13.49.839 Info: [#=zNDKAT964ZDXYtbBl4Q==] : [HAMLIB] Starting Hamlib service
11.13.49.841 Info: [#=zNDKAT964ZDXYtbBl4Q==] : [HAMLIB] Using existing connection: False
11.13.49.843 Info: [ProgramStorage] : [CAT STATUS CHANGED] Running: True
11.13.49.988 Info: [#=zNWAIyI4=] : [HAMLIB] DAEMON STARTED: C:\Log4OM2_2_23_0_0_portable\Portable\config\hamlib\rigctld.exe --model=2036 --rig-file=127.0.0.1:7820 -Z --vfo
11.13.52.093 Info: [#=zNWAIyI4=] : [HAMLIB] Hamlib Process exit code: 2
11.13.52.103 Info: [#=zNWAIyI4=] : [HAMLIB] DAEMON STOPPED. Hamlib instance terminated
11.13.52.983 Error: [HamlibEngine][#=zWApzMZA5Z8gD$sSK9pwMVq0=] : [EXCEPTION] No connection could be made because the target machine actively refused it 127.0.0.1:4532
11.13.52.993 Info: [HamlibEngine] : [HAMLIB] Stop polling. Timeout True
11.13.52.999 Info: [ProgramStorage] : [CAT STATUS CHANGED] Running: False
73's,
OH6PP Pena
Re: Hamlib does not stay connected
Known issue which is to be resolved for the next release
OH6PP
Post by OH6PP »
HI
Thans for the quick response. No need to struggle with this problem anymore :)
Any idea when next release will be out?
73's,
OH6PP Pena
