Maybe doing something wrong, but I am not seeing the comments fields in QSL Comments fields logging on the eQSL.cc site?
I have added comments to the following screens in various tests, but not sure which one should work.
Started with the settings;
That didn't work, so I added to the F2 tab and tried with and without padlock ticked;
But still don't see the text coming through on QSOs;
Am I missing anywhere else?
Thanks.
eQSL not populating comments?
Re: eQSL not populating comments?
Some more data. Just pulled a section of the logs in Debug mode, and looks like the data is being passed to eQSL.cc.
Has anyone else got the same issue?
I'll contact eSQL as well to see if this is an issue their side.
2022-10-09 14:40:46.2852 INFO: [#=zRfvcuOh5EExbm1abEYFyyO8=] : [DELAYED SEND QSO ASYNC] Aligning QSO process started...
2022-10-09 14:40:46.2941 INFO: [#=zNslaa9L0lBNLkWQvYN0gU9C0zD87] : [EQSL UPLOAD] Uploading QSO on EQSL: HB9HQX|09/10/2022 14:37:45|30m|FT8
2022-10-09 14:40:46.2961 INFO: [AdifManagement] : Begin export single QSO to ADIF string
2022-10-09 14:40:46.2971 INFO: [AdifManagement] : Export QSO to ADIF file completed
2022-10-09 14:40:46.2981 DEBUG: [#=zNslaa9L0lBNLkWQvYN0gU9C0zD87][MoveNext] : [EQSL UPLOAD] https://www.eqsl.cc/qslcard/importADIF. ... 143745+%3cCOMMENT%3a34%3eThank+you+for+your+QSO.+73s.+M0ODH+%3cDXCC%3a3%3e287+%3cFREQ%3a9%3e10.137355+%3cMY_CNTY%3a6%3eSurrey+%3cMY_GRIDSQUARE%3a6%3eIO91tj+%3cSTATION_CALLSIGN%3a5%3eM0ODH+%3cRST_RCVD%3a3%3e%2b07+%3cRST_SENT%3a3%3e-13+%3cEOR%3e%0d%0a
2022-10-09 14:40:46.3001 DEBUG: [#=zAm4_BTkMRgqavflUdPZzmrU=][MoveNext] : GetStringFromUrlAsync: Retrieving data from URL https://www.eqsl.cc/qslcard/importADIF. ... R%3e%0d%0a
2022-10-09 14:40:46.8315 DEBUG: * [#=zAm4_BTkMRgqavflUdPZzmrU=][MoveNext][532 ms] : GetStringFromUrlAsync: Data from URL https://www.eqsl.cc/qslcard/importADIF. ... R%3e%0d%0a downloaded
2022-10-09 14:40:46.8505 INFO: [#=zN5L8TIbg21EIR8yVfg==] : [EQSL UPLOAD] Qso updated/added
2022-10-09 14:40:46.8525 INFO: * [#=zNslaa9L0lBNLkWQvYN0gU9C0zD87][558 ms] : [EQSL UPLOAD] ###### END ######
2022-10-09 14:40:46.8544 INFO: [#=zZrkemweclQci19E1y3eOl0U=] : [QRZCOM UPLOAD] Uploading QSO on QRZ.COM: HB9HQX|09/10/2022 14:37:45|30m|FT8
2022-10-09 14:40:46.8554 INFO: [AdifManagement] : Begin export single QSO to ADIF string
2022-10-09 14:40:46.8574 INFO: [AdifManagement] : Export QSO to ADIF file completed
Feel free to ask Eqsl, we send the information but after that it's down to eQSL
If they have changed something, then they should notify software developers
wouldn't that be nice if they did.If they have changed something, then they should notify software developers
I've logged an issue on their forums as well, and will report back if there's any progress.
Just for the avoidance of doubt. Am I correct in assuming that the text in the "Confirmations Settings" is what gets populated in the interface?
Thanks.
OK got a response from eQSL;
"No issue,
FAQ :
The ADIF tag COMMENT is used for private comments about the QSO. We found out a decade ago that people did NOT want those comments disclosed on their cards! The ADIF tag QSLMSG is designed to be used for QSL Card Comments. That is the one we display on the eQSL card.
73 - F6DKQ"
So looking back at the log file extract below, I can't see the QSLMSG tag listed. Is there something I need to do to enable this?
Thanks.
"No issue,
FAQ :
73 - F6DKQ"
Thanks.
Code: Select all
2022-10-09 14:40:46.2981 DEBUG: [#=zNslaa9L0lBNLkWQvYN0gU9C0zD87][MoveNext] : [EQSL UPLOAD] https://www.eqsl.cc/qslcard/importADIF.cfm?ADIFData=%3cEQSL_USER%3a5%3eM0ODH%3cEQSL_PSWD%3a14%3eHspamspamspamm9%3ceoh%3e%3cAPP_EQSL_QTH_NICKNAME%3a8%3eHome+QTH%3cCALL%3a6%3eHB9HQX+%3cBAND%3a3%3e30m+%3cMODE%3a3%3eFT8+%3cQSO_DATE%3a8%3e20221009+%3cTIME_ON%3a6%3e143745+%3cCOMMENT%3a34%3eThank+you+for+your+QSO.+73s.+M0ODH+%3cDXCC%3a3%3e287+%3cFREQ%3a9%3e10.137355+%3cMY_CNTY%3a6%3eSurrey+%3cMY_GRIDSQUARE%3a6%3eIO91tj+%3cSTATION_CALLSIGN%3a5%3eM0ODH+%3cRST_RCVD%3a3%3e%2b07+%3cRST_SENT%3a3%3e-13+%3cEOR%3e%0d%0a
2022-10-09 14:40:46.3001 DEBUG: [#=zAm4_BTkMRgqavflUdPZzmrU=][MoveNext] : GetStringFromUrlAsync: Retrieving data from URL https://www.eqsl.cc/qslcard/importADIF.cfm?ADIFData=%3cEQSL_USER%3a5%3eM0ODH%3cEQSL_PSWD%3a14%3espamspamspamm9%3ceoh%3e%3cAPP_EQSL_QTH_NICKNAME%3a8%3eHome+QTH%3cCALL%3a6%3eHB9HQX+%3cBAND%3a3%3e30m+%3cMODE%3a3%3eFT8+%3cQSO_DATE%3a8%3e20221009+%3cTIME_ON%3a6%3e143745+%3cCOMMENT%3a34%3eThank+you+for+your+QSO.+73s.+M0ODH+%3cDXCC%3a3%3e287+%3cFREQ%3a9%3e10.137355+%3cMY_CNTY%3a6%3eSurrey+%3cMY_GRIDSQUARE%3a6%3eIO91tj+%3cSTATION_CALLSIGN%3a5%3eM0ODH+%3cRST_RCVD%3a3%3e%2b07+%3cRST_SENT%3a3%3e-13+%3cEOR%3e%0d%0a
2022-10-09 14:40:46.8315 DEBUG: * [#=zAm4_BTkMRgqavflUdPZzmrU=][MoveNext][532 ms] : GetStringFromUrlAsync: Data from URL https://www.eqsl.cc/qslcard/importADIF.cfm?ADIFData=%3cEQSL_USER%3a5%3eM0ODH%3cEQSL_PSWD%3a14%3espamspamspamm9%3ceoh%3e%3cAPP_EQSL_QTH_NICKNAME%3a8%3eHome+QTH%3cCALL%3a6%3eHB9HQX+%3cBAND%3a3%3e30m+%3cMODE%3a3%3eFT8+%3cQSO_DATE%3a8%3e20221009+%3cTIME_ON%3a6%3e143745+%3cCOMMENT%3a34%3eThank+you+for+your+QSO.+73s.+M0ODH+%3cDXCC%3a3%3e287+%3cFREQ%3a9%3e10.137355+%3cMY_CNTY%3a6%3eSurrey+%3cMY_GRIDSQUARE%3a6%3eIO91tj+%3cSTATION_CALLSIGN%3a5%3eM0ODH+%3cRST_RCVD%3a3%3e%2b07+%3cRST_SENT%3a3%3e-13+%3cEOR%3e%0d%0a downloaded
Sorry I forgot to mention, I did a search of forums and found the same issue reported here;
https://forum.log4om.com/viewtopic.php? ... msg#p40457
Last message says they couldn't find QSLMSG in their log file either.
I did include extract of my logfile, but changed the passwords in the text.
Thanks.
Thanks.
Partly right! Comments is the comment that is public and NOTES are the private comments like 'this guy's a nutter'FAQ :
73 - F6DKQ"
However, see image below
And we export it in the ADIF export file as below
Thanks Terry for walking me through this.
I'd populated all these fields, so not sure why it was not working. Just went through and set everything up again and tracked it through the process and it works if I add a QSO manually. So I'll do some more testing later using WSJT-X and FT8 and see if it works there.
Right now though I can see the QSLMSG field is now appearing in the log;
"QSLMSG%3a36%3eThank+you+for+your+QSO.+73s+Darrell."
And the QSL Text is going through the interface to eQSL.cc; Thank you for your patience.
m0odh wrote: 10 Oct 2022, 14:21 it works if I add a QSO manually. So I'll do some more testing later using WSJT-X and FT8 and see if it works there.
The automatic upload is just an automated manual upload and contains exactly the same information.
Using WSJT variants make no difference unless you have set the WSJT program to auto upload to eQSL? in which case eQSL @ Log4OM will treat them as duplicates and not upload the QSO's
