CW report input
Pa0ply
CW report input
Post by Pa0ply »
Hi Team,
I just installed the excellent program on my new PC as the other one crashed.
Now I faced an issue while putting QSO’s in the log.
For EME where the CW signals can be really weak, it is common sense to use TOM type of reports.
Unfortunately the input field does not allow to put: TTT or OOO or MMM report.
Even when I edit the logged QSO, I still have this problem.
Can you add such feature in the next release, please?
Thanks in advance,
Jan, PA0PLY
Re: CW report input
Pa0ply wrote: 12 Dec 2022, 11:18 Hi Team,
Thanks in advance,
Jan, PA0PLY
Jan,
You can edit the rst.xml file to suit your needs.
You can reach the Resource Editor at: Settings / Resrouce Editor ... then select the rst.xml file in the left box, make your edits and then tap 'save'.
The modified file will then have the _user extension added to the name. Then close the Resource Editor and then restart Log4OM and your now edited rst_user.xml file will be recognized for use.
Pa0ply
Re: CW report input
Post by Pa0ply »
Nolan,
Thanks for this note.
Will do so.
Br. Jan
