Hi , Ive just done a install of v 2.25.0.0 on a different computer and the send spot now works with second screen and the export adif file also works.
I am now going to backup my log and take copy off computer and delete Log4om off this computer and reinstall new copy.
Thank you for your help.
Merry Christmas and Happy New Year
73 John ZL3TRR
SEND SPOTS
Re: SEND SPOTS
FIXED- BOTH PROBLEMS
I uninstalled Log4OM and restarted computer.
I downloaded a clean copy of 2.25.0.0 and installed.
I connected to database, and input a callsign and which populated data for log and made sure cluster and cluster server was connected
I then tried to "Send Spot" and it DID NOT WORK (Second screen did not come up)
I then went to Log4OM Configuration / edit program config and RESET TO FACTORY SETTINGS.
SEND SPOT and Export ADIF --NOW WORK -- FANTASTIC
I had to input my personal data back in but that's okay to FIX this problem.
73 John ZL3TRR
73 John ZL3TRR
