Cant save recent QSO
n3se
Post by n3se »
Made my first contact with a new rig entered Persons call hit enter nothin log is blank Do I have to set up a SQLlite sight just to use log4om I have no clue what I am doing with that Please help before I just give up with
Re: Cant save recent QSO
You need to read the Quick start Guide here https://www.log4om.com/l4ong/usermanual ... ide_EN.pdf
User guide here https://www.log4om.com/l4ong/usermanual ... NG_ENU.pdf
Watch the Quick start video tutorials here https://www.youtube.com/@terrygenes2236
The SQLite database can be created within Log4OM, it takes seconds but you clearly skipped that pert of the setup
n3se
Post by n3se »
I am not understanding the Sqllite I made a file hamlogs and used it but still nothing. Plus log4om doesn't show it as a SQLite file just a log4om file I'm sorry but confused.
n3se
Post by n3se »
G4POP wrote: 22 Dec 2022, 23:55 You need to read the Quick start Guide here https://www.log4om.com/l4ong/usermanual ... ide_EN.pdf
I have made a new file in log4om 2 named it ham logs past test but still nothing doesn't even show as a SQLite file on my PC sorry but I'm lost
Where did you save the file to - location path?
n3se
Post by n3se »
G4POP wrote: 23 Dec 2022, 09:51 Where did you save the file to - location path?
I'll do a screenshot and share when I get home from work tonight
n3se
Post by n3se »
Screenshot sql.png (45.71 KiB) Viewed 665 times
n3se
Post by n3se »
Screenshot logbook (2).png (201.47 KiB) Viewed 664 times
n3se
Post by n3se »
also I see a lock on everything on the log
