Cannot save QSO's
n3se
Cannot save QSO's
Post by n3se »
I have read the online manual and watched numerous videos and still won't save it worked once haven't changed a thing . Can I please get some help I really want this program to work Is this a windows 11 issue?
Re: Cannot save QSO's
Are you connected to a database- see bottom right of main window for path to database or message 'not connected'
n3se
Post by n3se »
G4POP wrote: 04 Jan 2023, 22:36 Are you connected to a database- see bottom right of main window for path to database or message 'not connected'
Yes if what I circled in the snapshot is what you are referring too
Screenshot 2023-01-04 175113 (2).png (58.98 KiB) Viewed 822 times
So you enter a call and it does a lookup and then you save by what? Enter key on keyboard or Plus icon on right side?
Do you see any error message?
Have you checked the logfile for errors?
What is the Log4OM version number?
n3se
Post by n3se »
G4POP wrote: 04 Jan 2023, 23:12 So you enter a call and it does a lookup and then you save by what? Enter key on keyboard or Plus icon on right side?
Ok Version 2.25 0.0 I either hit enter or if the plus symble is highlighted green I click on it
n3se
Post by n3se »
Not sure about logfile errors I test it and it said past Not an IT person so beyond that out of my pay grade lol
so what happens when you try to save a qso? Error message or what?
I suspect one drive is causing the issues can you move your database to a physical location or Google Drive?
n3se
Post by n3se »
G4POP wrote: 05 Jan 2023, 08:49 so what happens when you try to save a qso? Error message or what?
I tried that just now working so far. Thanks for helping my friend 73's Jim
n3se wrote: 05 Jan 2023, 13:37
Windows security limiting writing to one drive after an update of Windows, had this before
Good luck - Enjoy
n3se
Post by n3se »
Back to not working againI get no error messages. I hit enter the call sign and info goes blank and nothing is logged. I go back to configuration and my SQL passes testing go and check that the sql file is still where I saved it all is good. I give up. I just wished someone would please help.
