Old Icom Ic820h and cat
Hi guys. Can anyone help me to use this radio via cat with log4om? I use a ct17 cable but there is no way to read frequency
all checked... Baud, port but not works. Grazieee
Re: Old Icom Ic820h and cat
Danilo,Iz6jpk wrote: 18 Jan 2023, 20:35 Hi guys. Can anyone help me to use this radio via cat with log4om? I use a ct17 cable but there is no way to read frequencyall checked... Baud, port but not works. Grazieee
Which CAT option are you using?
Did you read about Radio CAT Control starting on Page 22 of the current English version User Guide?
Have you watched the You Tube video that Terry did about CAT Control?
https://www.youtube.com/watch?v=cF8I-tJlv6c
There is an 'ini' file for the IC-820 in the Omnirig Rigini selection list. I can't speak for Hamlib.
If using Omnirig is it the version from DXAtlas that is currently V 1.2 ?
Hi Nolan thanks for answering. I download the Last version of log4om, 1.2 omnirig. Try to use omnirig. I download and zip into the folder also che ini list. The strange thing is that the radio works fine with the ct17 and orbitron for example but not with log4 om
No one idea?
Are you running Log4OM as an Administrator?
If you are, and still not working, paste your OmniRig settings here.
Ok Doug, during the afternoon i will send here the screen of confogiration but i think the problem is ini file..... Omnirig doesnt work in admin also
as i said the radio with the same ct17 cable works fine with omnirig. Thanks
nothing to do
- Immagine 2023-01-20 183821.png (89.92 KiB) Viewed 4117 times
- Immagine 2023-01-20 183801.png (177.54 KiB) Viewed 4117 times
- Immagine 2023-01-20 183741.png (189.73 KiB) Viewed 4117 times
.....client
- Immagine 2023-01-20 183930.png (51.53 KiB) Viewed 4117 times
- Immagine 2023-01-20 183851.png (50.89 KiB) Viewed 4117 times
If OmniRig Client is not connecting, that indicates that the issue is not with Log4OM.
In any case, are you starting OmniRig as Administrator? When you tried Client, was Log4OM NOT running?
Yes Doug, all tested with admnistrator . Yes is correct, the problem seems to be not with log4om. It seems a problem with the ini file????
