Version 2.26.0.0 and Grid Squares
VK7XX
Re: Version 2.26.0.0 and Grid Squares
Post by VK7XX »
for what it's worth, which in fact is a hell of a lot, the info provided above by Nolan, KI5IO is very very important, Thank you heaps Nolan... in particular, the second image... Once those settings are changed, version 2.26.0.0 will once again work correctly. Just why it was changed from version 2.25.0.0. to the current version is anyones guess.. The Main thing tho is that thanks to Nolan, all works correctly now.
(Settings / program config / Software Configuration / Info Providers / Configuration)
Regards
John
VK7XX
GM7GAX
Post by GM7GAX »
Another thanks to Nolan, KI5IO
DL4DBM
Post by DL4DBM »
Thanks Nolan! I had the same problem....
DO9KW
Post by DO9KW »
I had the same issue allthough I am a XML subscriber on QRZ.com.
My GRID was also shown as the country GRID and not my real locator, that changed back to normal after doing Nolans settings.
In v 2.25.0.0 it was working without changing anything..
I operate a lot of FT8 and the logged GRID from the WSJT-X ADI file is different now from the stored GRID in Log4OM and because of this it also gets uploaded with the wrong Data to the external sources such as LotW, QRZ.com and eQSL.cc
The first Screenshot shows how the QSOs were saved in Log4OM and the second screenshot is an extract from my WSJTX.log (in the adif file the same GRIDs are saved of course)
How can I correct the GRIDs properly in the Log4OM log?
73s
DO9KW - Stefan
Screenshot 2023-01-24 143027.jpg (166.54 KiB) Viewed 821 times
Screenshot 2023-01-24 142907.jpg (112.69 KiB) Viewed 821 times
73 Stefan
